SW-Motech Handlebar Risers - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 01-05-2016, 12:28 PM Thread Starter
So I just installed the risers last night in about 5-10 minutes. Seemed like an easy job. Having never done it before, though, I'm wondering if there will be any issues with the wiring and cables going to the brakes and throttle? No tightness when turning? I couldn't do much last night in terms of turning the front wheels as it was up on stands but I figured people here would know if anything gets tight on the cables after installing a riser block.
2008 Kawasaki Versys 650
Barkbuster Storm Guards
SW Motech Riser Block
Givi D405ST Windscreen
Ididar is offline
post #2 of 5 (permalink) Old 01-05-2016, 12:34 PM
You won't have any issues with the cables or wiring. I had the SW-Motech Risers before i replaced them with the Motowerks Anti-Vibe Risers...
post #3 of 5 (permalink) Old 01-05-2016, 01:15 PM
W/ 2" ROX Risers I've had NO issues....
post #4 of 5 (permalink) Old 01-05-2016, 06:38 PM
!+ Ditto.
My Rox 2" Riser work with standard cable length.
But I did have to put a bit of PVC tubing on the clutch cable as it was rubbing on the stock Bar riser and taking off the paint.
Gigitt is offline
post #5 of 5 (permalink) Old 01-06-2016, 04:08 PM
Here's a pic of the amount of clearance I have on the clutch cable....
