Bullet connectors over the radiator left side? - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By invader
post #1 of 18 (permalink) Old 12-07-2015, 10:42 PM Thread Starter
2linby's Avatar
Anyone know what these go to? They were just hanging out not connected to anything. Lefts of bike over the top of the radiator.
I used a meter to check voltage and nothing off or on or running.
Thanks! It's a 2014 Versys.
COG# 5539
IBA# 15034
Team Oregon MC Instructor
"2linby" Get it? "Tooling by"
"Everything is simple, nothing is easy".
2linby is offline
post #2 of 18 (permalink) Old 12-07-2015, 10:53 PM
post #3 of 18 (permalink) Old 12-08-2015, 01:08 AM
black and yellow are ground blue and white is switched + power... 4 prong plug...no clue
post #4 of 18 (permalink) Old 12-08-2015, 01:17 AM
4 prong connector is for a relay to power those 12V accessory wires.
post #5 of 18 (permalink) Old 12-08-2015, 10:28 AM
ok then on will be a hot 12V one will be ground one will be switched power/trigger and one will be ground, easy to find what one is what
post #6 of 18 (permalink) Old 12-08-2015, 03:10 PM Thread Starter
2linby's Avatar
I tested with my fluke with these from off to key on and with bike running and there was no voltage. Schematic shows the four pin to be to a test connection. But the bullet connectors don't seem to show up on the wiring diagrams.
Anyone else?
COG# 5539
IBA# 15034
2linby is offline
post #7 of 18 (permalink) Old 12-08-2015, 03:15 PM Thread Starter
2linby's Avatar
Perfect! Thanks!
COG# 5539
IBA# 15034
2linby is offline
post #8 of 18 (permalink) Old 12-08-2015, 03:28 PM
If you go to the accessories page on the Kawasaki site you can find installation instructions for all of the add-ons. The photos show what all of the various connections are.
scutrbrau is offline
post #9 of 18 (permalink) Old 12-08-2015, 03:55 PM
Anyone else?
No relay, no power.
2linby likes this.
post #10 of 18 (permalink) Old 12-08-2015, 10:00 PM Thread Starter
2linby's Avatar
No relay, no power.
Any idea as to the load rating of this circuit? thanks!
COG# 5539
IBA# 15034
2linby is offline
post #11 of 18 (permalink) Old 12-08-2015, 10:20 PM
Patillas's Avatar
Are those cables in a first generation Versys too?
Sent from my SM-G920T using Tapatalk
Patillas is offline
post #12 of 18 (permalink) Old 12-09-2015, 03:19 AM
It runs through a 5A fuse... 2010+ models have it.
That's all you need to know.
post #13 of 18 (permalink) Old 12-09-2015, 07:43 AM
Patillas's Avatar
Arghh, mine is a 2008. Thanks!
Patillas is offline
post #14 of 18 (permalink) Old 12-10-2015, 01:08 AM
These are where power outlet and heated grips plug into , These both require the accessory relay to work
Relay part number for the 2010 - 2014 and 12volt socket
DC Power Socket - Relay Kit
Item# 99994-0195
the little rubber box looking thing is the relay next to the power out let
Mounting and wiring instructions for relay
https://www.kawasaki.com/Content/Upl..._999940195.pdf
Socket relay
DC 12 Volt Socket
Item# 99994-0194
instruction on mounting
https://www.kawasaki.com/Content/Upl..._999940194.pdf
Hope this helps
Heated grips for newer model will work on this model
Grip Heater Kit
Item# 99994-0193
Instructions
https://www.kawasaki.com/Content/Upl..._999940193.pdf
Motojunkee is offline
post #15 of 18 (permalink) Old 12-10-2015, 02:22 PM
Berty77's Avatar
Never use the trigger wire as a supply wire, when I got my new bike off the showroom floor I started scratching around for power wires and without doing much investigation connected my spots to the trigger wire. Needless to say I fried the positive and negative wires together after a few rides and almost destroyed my harness, the trigger +12V wire is not fused and needs to run to a relay only, the square plug is set up for the OEM relay. If installed, you can run up to 5amps like Invader said, that orange loose fuse under your seat is its fuse and spare.
**Ride the Karoo**
Berty77 is offline
post #16 of 18 (permalink) Old 12-10-2015, 09:41 PM
Baron650's Avatar
Unhappy
Yikes!
Thanks for sharing that!
I just installed an accessory fuse panel with an Automotive relay, intending to hook up GPS power, heated grips, and power for the heated vest. I looked at the plug, but I wanted bigger wire and a 30 amp fuse on the power leg to the accessory panel.
Anybody see a problem with utilizing those two grounds for my accessories?
Baron650 is offline
post #17 of 18 (permalink) Old 12-11-2015, 09:34 AM
Originally Posted by Baron650 View Post
Yikes!
i dont really see any problem with useing them, but is it really that hard to add a heavy gauge wire ground?
post #18 of 18 (permalink) Old 12-12-2015, 04:32 PM Thread Starter
2linby's Avatar
I found a used relay PN Omron 27002-1086 for $6.97 on eBay. Works great!
COG# 5539
IBA# 15034
2linby is offline
