Chain & Sprocket change with 15t / 43t gearing - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 11-30-2015, 10:49 AM Thread Starter
Andymancam's Avatar
Hey folks!
I've been at it again messing with my Versys.
This time new chain and sprocket. I say sprocket because i left the front alone. The change came as a result of early chain death due to misalignment.
I've opted for a 43 tooth rear and as a result have dropped 2 links from the chain down to just 112.
But don't take my word for it. Of COURSE there's a couple of videos of me doing it!
And there's a cautionary tale about those pesky chain adjuster bolts in there too. Heed thee well!!
NEW Chain And Sprockets: https://www.youtube.com/playlist?lis...bT-M1Ym5yXI8Ie
Andymancam is offline
post #2 of 6 (permalink) Old 12-03-2015, 03:44 PM
Andy - FWIW - I changed my countershaft sprockets at roughly HALF the mileage I changed my rear ones, BECAUSE they were worn, teeth starting to 'hook'....
post #3 of 6 (permalink) Old 12-04-2015, 03:11 PM
kawdog's Avatar
Was that the oem rubber insulated steel front sprockets or the steel replacement front sprockets that wore out so fast? I had 'heard' the rear wear out faster (on all Jap bikes) and was wondering if that was a price to pay for the superior rubber insulated front sprockets.
THANKS!!
kawdog is offline
post #4 of 6 (permalink) Old 12-04-2015, 04:40 PM
BLACK DOG's Avatar
Figuring that the front goes around roughly three times as many as the rear, I'd guess that the front gets more wear in a given work cycle.
BLACK DOG is online now
post #5 of 6 (permalink) Old 12-04-2015, 05:20 PM
one would think.... ive had bikes (drz's) that ate rear sprockets like none other, but the front would last for almost ever
post #6 of 6 (permalink) Old 12-06-2015, 05:13 PM
Originally Posted by kawdog View Post
Was that the oem rubber insulated steel front sprockets or the steel replacement front sprockets that wore out so fast?...
I replaced the OEM and aftermarket countershaft sprockets at roughly the SAME mileage interval. On BIG RED which has 59,520 miles - at 29,642 miles, then AGAIN at 54,228 miles. (The rear sprocket was changed at the SAME time I replaced the ORIGINAL chain at 56,901 miles.) YRMV!
Correct.
