Loose wires for ??? - Kawasaki Versys Forum
Like Tree3Likes
  • 1 Post By invader
  • 1 Post By Motojunkee
  • 1 Post By BKP
post #1 of 14 (permalink) Old 11-27-2015, 03:35 PM Thread Starter
Biz
Biz's Avatar
Loose wires for ???
Just rode my '14 Versys home two nights ago and noticed 3 loose wires loose under the left front cowling. See pic. Can anyone tell me what the intended purpose for these might be; the dealer couldn't help me? Two black wires with yellow stripe, One white wire with light blue stripe. I thought maybe some hot lines for future add-ons, like extra lights, heated grips, etc. If they're hot, shouldn't they be covered? Any help here appreciated.
Biz is offline
post #2 of 14 (permalink) Old 11-27-2015, 04:13 PM
CamBkm is offline
post #3 of 14 (permalink) Old 11-27-2015, 07:57 PM
That's your 12V accessory outlet... You just need a relay to make it work.
http://www.kawasakiversys.com/forums...r-plug-up.html
aboyandhisversys likes this.
post #4 of 14 (permalink) Old 11-27-2015, 08:17 PM Thread Starter
Biz
Biz's Avatar
OK help. So if I buy something like heated grips, they would come with that relay that accepts these 3 loose wires? Or do I have to divine what kind of relay I need... because I don't know how to specify proper electrical components, especially on something like this. Anybody have a picture of what they did? Thanks.
Biz is offline
post #5 of 14 (permalink) Old 11-28-2015, 01:26 AM
These are where power outlet and heated grips plug into , These both require the accessory relay to work
Relay part number for the 2010 - 2014 and 12volt socket
DC Power Socket - Relay Kit
Item# 99994-0195
the little rubber box looking thing is the relay next to the power out let
Mounting and wiring instructions for relay
https://www.kawasaki.com/Content/Upl..._999940195.pdf
Socket relay
DC 12 Volt Socket
Item# 99994-0194
instruction on mounting
https://www.kawasaki.com/Content/Upl..._999940194.pdf
Hope this helps
Heated grips for newer model will work on this model
Grip Heater Kit
Item# 99994-0193
Instructions
https://www.kawasaki.com/Content/Upl..._999940193.pdf
Biz likes this.
Motojunkee is offline
post #6 of 14 (permalink) Old 11-28-2015, 09:33 AM Thread Starter
Biz
Biz's Avatar
Excellent, thank you for the details on this rigging.
Biz is offline
post #7 of 14 (permalink) Old 12-01-2015, 12:52 AM
BKP
BKP's Avatar
The relay will also enable the Kawi gear indicator.
Ride safe...
Barry
2015 Versys 650 Pearl White
[space holder for farkles...]
BKP is offline
post #8 of 14 (permalink) Old 05-02-2016, 11:05 PM
hcb
I realize this post is old as heck but...just in case...how does this relay "enable" the gear indicator?
--HC
BMW, Honda, Kawasaki, Suzuki, Yamaha, Huffy...anything but a Harley.
hcb is offline
post #9 of 14 (permalink) Old 05-03-2016, 12:26 AM
--HC
is just switched power to tell it to turn on when the key is on and off when the key is off
post #10 of 14 (permalink) Old 05-04-2016, 08:45 PM
BKP
BKP's Avatar
--HC
As above, the relay is required if you're going to use the pre-terminated connection for the gear indicator (as well as the power plug connection). In that sense, it enables those particular connections. The advantage (for both the gear indicator, and power plug -- both installed on my bike) is that it's switched. If you install a gear indicator (or most power outlets) on a non-switched line, there's residual power drain... small... but effectual on the battery.
Ride safe...
Barry
BKP is offline
post #11 of 14 (permalink) Old 05-01-2017, 01:39 PM
Snecer's Avatar
one positive + (W/BL, white/black) together for 12V outlet & heated grips
2.
two separate negative - (BK/Y, black/yellow) for 12V outler & heated grips
3.
5A fuse for accessories (12V outlet & heated grips) is under the seat (behind with spare fuse 5A)
Snecer is offline
post #12 of 14 (permalink) Old 05-01-2017, 01:58 PM
I'll drop a note in passing - don't bother buying the OEM heated grips, which are a contradiction in terms. The price is an inverse relation to the performance. I refer to mine as 'tepid grips' for a very good reason. FYI.
aboyandhisversys is offline
post #13 of 14 (permalink) Old 05-09-2017, 08:14 PM
MTingle's Avatar
Currently have the Oxford heated grips on my bike, the grips feel great in the hand and are very warm. Even on the lowest of settings they keep my hands warm, at 100% they are almost too hot.
MTingle is offline
post #14 of 14 (permalink) Old 05-11-2017, 02:28 AM
I agree about the oxford grips. I have a set on my Versys and they fit and work great. I like the five different heat settings. I have used them below freezing and they keep my hands toasty warm. The highest setting works great if you have thick gloves on. With thin gloves, the highest heat setting is uncomfortably warm even when the weather is below freezing.
Green Streak is offline
