How to Install Remote Garage Door Opener - Kawasaki Versys Forum
post #1 of 17 (permalink) Old 07-06-2010, 12:50 PM Thread Starter
I have always mounted a remote garage door opener on every bike I have owned. I don't want to carry a remote on my person. This also allows any rider in my family to open the door on the way out or return.
Start by opening up your spare remote. Solder 2 wires to the circuit board (1 on each side of the activation switch). They will run to the switch mounted on the bike.
For my switch I used Mcmaster Carr PN 6915K221. You must search on their site for the part number, I cant hotlink directly to it.
Basically, after drilling a hole in the side of the remote for my wiring to exit, I snapped it closed and wrapped it in Saran Wrap including a scrap piece of plastic so the remote buttons could not be pushed accidentally. Then made a small "hold down bracket" so it would not move.
I made a service loop (extra wire coiled out of the way) so I can pull it out to change the battery in the remote.
I drilled a hole in the fairing, installed switch and soldered the two wires to the switch. Now the remote switch activates the garage door while I'm still sitting on the bike.
Be careful that the solder lugs on the switch are short enough as not to touch the bar (where the helmet lock is). I had to trim the solder lugs shorter. If they are close to the bar, they could touch it with any flexing and activate your door when you don't want it to.
This thread is only a suggestion, feel free to show any other ideas on how you did yours or where you located your switch!
Good Luck!
post #2 of 17 (permalink) Old 07-06-2010, 01:02 PM
Jack425's Avatar
Thanks! This sounds better than my current solution of holding the remote in a pocket and squeezing randomly hoping to hit the button before I hit the driveway!
Jack425 is offline
post #3 of 17 (permalink) Old 07-06-2010, 01:34 PM
Robzilla's Avatar
That's exactly my approach too! Sometimes i've nearly hit the garage door with my front tire before I've managed to find the right button, and forget about fishing the remote out of my pocket wearing racing gloves.
Robzilla is offline
post #4 of 17 (permalink) Old 07-06-2010, 01:50 PM
5 Wheel Drive's Avatar
That sounds familiar!!!
Great idea ....
5 Wheel Drive is offline
post #5 of 17 (permalink) Old 07-06-2010, 01:51 PM Thread Starter
If you want another option...
post #6 of 17 (permalink) Old 07-06-2010, 02:08 PM
Nytrydr's Avatar
Nytrydr is offline
post #7 of 17 (permalink) Old 07-06-2010, 02:46 PM
Hardware's Avatar
Originally Posted by Capn Kirk View Post
I have always mounted a remote garage door opener on every bike I have owned...
Hey, thanks for the reminder...
So, does anybody know what that `extra’ fuse is for in the picture?
~~ Live Like You're Dying ~~
Hardware is offline
post #8 of 17 (permalink) Old 07-06-2010, 02:53 PM
Nytrydr's Avatar
Back up for the dylithium crystals.
Nytrydr is offline
post #9 of 17 (permalink) Old 07-06-2010, 03:05 PM
Very clever. And complicated. I installed my remote with heavy-duty velcro under the black panel to the left of the instruments. Protected from the weather and works fine.
hsfarber is offline
post #10 of 17 (permalink) Old 07-06-2010, 03:14 PM Thread Starter
I just looked in the 2010 factory service manual and in the appendix, it is listed as "Accessory Relay Fuse 5 A (Insert the connector from the bottom in the rear fender side bracket)"
That's it. No further mention on WTH it is..
Maybe for heated clothing or such?
post #11 of 17 (permalink) Old 07-06-2010, 03:53 PM
jettexas's Avatar
Velcro is a wonderful thing. Wish i invented it. I alternate between a garage door opener and a radar detector depending on my riding
jettexas is offline
post #12 of 17 (permalink) Old 07-06-2010, 09:48 PM
Mursili's Avatar
An earlier thread talked about using an "autoswitch."
http://www.kawasakiversys.com/forums...ead.php?t=1584
That way I could use the high-beam momentary switch on my '08 that sits there stubbornly unused. I am sure that I will "get right on that."
Actually, I will instead keep searching for the remote button while it sits in one of my jacket pockets.
Mursili is offline
post #13 of 17 (permalink) Old 07-07-2010, 12:40 AM
versysBKK is offline
post #14 of 17 (permalink) Old 07-07-2010, 09:11 AM
Hardware's Avatar
I just looked in the 2010 factory service manual ...
You got a 2010 service manual?! Geez, who do you know?! Show off! <grumble grumble>
Actually I’ve been meaning to get one myself but I’ve been hoping that they’d release it in an electronic format. With my aging eyes I find it easier to read on screen and I hate having to thumb thru paper pages searching for something... Yeah, I know... I’m spoiled!
Hardware is offline
post #15 of 17 (permalink) Old 07-07-2010, 09:50 AM
Not bad Kirk...Heres what I use though
http://shop.ebay.ca/i.html?_nkw=flash2pass
A click of the pass trigger and tada the door opens...Install time, 30 minutes and no foolin around with the wiring...Reciever just hooks into the high beam wire...
contractor is offline
post #16 of 17 (permalink) Old 07-07-2010, 10:08 AM Thread Starter
Showoff? You aint seen me showoff yet.. I only paid $15 on EBAY +$6 shipping for a factory paper version. I saw it listed one night (buy it now) and bought it on the spot. All the other paper versions on Ebay are for 07-09 for ~$50-$70. Dont know why the guy listed a 2010 so cheap??
Let me know if you ever need a page or three, I'll be glad to help you out.
post #17 of 17 (permalink) Old 07-08-2010, 04:46 PM
cls
I just hang a key fob garage door opener from a carribeaner off my belt loop: cheap, easy, and it works for all my bikes, truck, car, on foot, etc.
cls is offline
