Oil Filter Wrench - Kawasaki Versys Forum
post #1 of 19 (permalink) Old 03-31-2008, 02:21 PM Thread Starter
Oil Filter Wrench
I bought an oil filter wrench for the Versys today at Walmart. It only cost $3.26 and fits over the outside of the filter's end like a socket. You the put your 3/8 drive ratchet into opening of the device and spin the filter off. It's made in the USA by IMPERIAL, part no. IF-6567C.
jimstandinghorse is offline
post #2 of 19 (permalink) Old 03-31-2008, 09:46 PM
Good find!!
post #3 of 19 (permalink) Old 04-21-2008, 04:51 AM
what mm is this wrench?
roadkill is offline
post #4 of 19 (permalink) Old 04-22-2008, 07:24 AM
Torque?
What torque should be used when tightening the filter?
lost84001 is offline
post #5 of 19 (permalink) Old 04-22-2008, 11:20 AM
Nevermind. I found it on page 100 of the owners manual:
13 ft lbs for the filter
22 ft lbs for the drain plug
post #6 of 19 (permalink) Old 05-19-2008, 12:04 AM
nvoelsch's Avatar
I got lucky today. My sister had a mid-90's Toyota Cellica while in college and I still had the wrench for it. Sure enough, it fits the Versys oil filter as well!
nvoelsch is offline
post #7 of 19 (permalink) Old 05-19-2008, 08:54 AM
speaking of oil filters, does anyone have any cross references for other brands i might get at my local auto parts store instead of dealing with just the dealership part?
tsunamichop007 is offline
post #8 of 19 (permalink) Old 05-19-2008, 04:08 PM
K&N makes one that I just installed. It has a nut attached to the front of the filter and installing it was a snap. The part number is KN-303.
lanesplitter is offline
post #9 of 19 (permalink) Old 05-20-2008, 10:51 PM
OEM oil filter: 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket, 2.5" height, 2.7" OD. If you have the room, I recommend the longer filters.
http://www.calsci.com/motorcycleinfo/FilterXRef.html
-See Section [5]
Motorcycle Filters - None are recommended:
* AC Delco PF2135
* Carquest 85358
* FRAM PH6017A
* Honda 15410-MCJ-000
* K&N KN-204, about $13. Metric nut on end for easy removal. (KN-303 is the longer version)
* NAPA Gold 1358
* Purolator ML16817. Imported, not made by Purolator.
* STP SMO 17
* WIX 51358
Recommended filters - All have superior filtering:
-About 2.5 inches long:
* AC Delco PF1237
* Amsoil EaOM103, $14.80
* Purolator Pure One PL14612, about $6.
* Mobil M1-108, about $12. Made by Champion.
* Bosch 3300, about $6. Made by Champion.
* Baldwin B1400
* Emgo 10-82230
* Firestone TF2876
* Hastings LF113
* NAPA Gold 1365
* Purolator L14612
* STP S-02876
* Vesrah SF-4007
* WalMart SuperTech ST6607
* WIX 51365
-About 3.25 inches long:
* Amsoil EaOM103C, $17.00
* Purolator Pure One PL14610, about $6.
* Mobil 1 M1-110, about $10. Made by Champion.
* Bosch 3323, about $6. Made By Champion.
* WalMart SuperTech ST7317, about $2. Made by Champion.
-Automobile Filters, about 3.25 inches long:
* AC Delco PF-2057
* Auto Pro 2356
* Autopride CF240AP
* Baldwin B1402
* Carquest 85356
* Carquest Red B4620
* Casite CF240
* Castrol 7317
* Champion Labs Ph2867
* Defense Filters Dl7317
* Deutsch D-370
* Federated Filters LF240F
* Fram Extended Guard XG7317
* Fram Extra Guard PH7317
* Fram Tough Guard TG7317
* Group 7 V4610
* Group 7 V4620
* Hastings LF240
* Mighty M4612
* Motorcraft Long Life FL-821
* Napa FIL1356
* Napa Gold 1356
* Nippon G6Y0-14-302 A
* Parts Plus PH2867
* Pennzoil PZ-109
* Penske 7317
* Powerflo SL14610
* Powerflo SL14620
* Pro Gauge PGO-4620
* Pro Tec 164
* Promotive PH4610
* Pronto PO3593A
* Purolator L14610
* Service Champ OF-4622
* Shell SH48
* Shell SH529
* Stp S-02867.
* Valvoline VO50
* Warner PH2867
* Wix 51356
I got 6 high quality Nippon G6Y0-14-302 A PH oil filters from Ebay for only $12.99 ($12.99 for 6, not $12.99 each) plus shipping;
http://cgi.ebay.com/ebaymotors/6-Nip...m270238494462&
post #10 of 19 (permalink) Old 09-03-2010, 10:11 AM
Hardware's Avatar
Note that the article at http://www.calsci.com/motorcycleinfo/FilterXRef.html has removed quite a few of the recommended filters from the list.
~~ Live Like You're Dying ~~
Hardware is offline
post #11 of 19 (permalink) Old 09-03-2010, 04:27 PM
The filters from ebay are no longer available.
ScottyNeal is offline
post #12 of 19 (permalink) Old 09-03-2010, 04:50 PM
Nytrydr's Avatar
-See Section [5]
* AC Delco PF2135
* Carquest 85358
* FRAM PH6017A
* NAPA Gold 1358
* STP SMO 17
* WIX 51358
* AC Delco PF1237
* Baldwin B1400
* Emgo 10-82230
* Firestone TF2876
* Hastings LF113
* NAPA Gold 1365
* Purolator L14612
* STP S-02876
* Vesrah SF-4007
* WIX 51365
* AC Delco PF-2057
* Auto Pro 2356
* Autopride CF240AP
* Baldwin B1402
* Carquest 85356
* Casite CF240
* Castrol 7317
* Deutsch D-370
* Group 7 V4610
* Group 7 V4620
* Hastings LF240
* Mighty M4612
* Napa FIL1356
* Napa Gold 1356
* Parts Plus PH2867
* Pennzoil PZ-109
* Penske 7317
* Powerflo SL14610
* Powerflo SL14620
* Pro Tec 164
* Promotive PH4610
* Pronto PO3593A
* Purolator L14610
* Shell SH48
* Shell SH529
* Stp S-02867.
* Valvoline VO50
* Warner PH2867
* Wix 51356
well if your putting it on your Versys, I must have the room for the longer one too?
Nytrydr is offline
post #13 of 19 (permalink) Old 09-03-2010, 04:53 PM
Nytrydr's Avatar
I bought the wrench from Wall Mart and it works on the Fram filter but not the oem filter? Maybe its not the same.
Nytrydr is offline
post #14 of 19 (permalink) Old 09-03-2010, 06:08 PM
WV76X's Avatar
I can confirm that the current Wal Mart cheap wrench doesn't work on the oem. I think it is a Fram branded wrench.
- Zac
WV76X is offline
post #15 of 19 (permalink) Old 09-03-2010, 08:03 PM
Nytrydr's Avatar
Mine is a Fram oil filter wrench, F1105. It fits the Fram filter not the Kawi OEM
My bad, not the same wrench or socket for the filter.
Donn
Nytrydr is offline
post #16 of 19 (permalink) Old 09-04-2010, 05:37 AM
djg
The Walmart wrench worked on my OEM filter after I wrapped some masking tape around the filter. The OEM was installed exceedingly tight, IMHO. I applied torque to the old filter very slowly, and it finally started to move.
I started torquing the new filter to spec with a calibrated wrench. and I stopped short of the recommended spec, it seemed way too tight to me.
So my Supertech filter is installed by feel, and no leaks in 700 miles.
djg is offline
post #17 of 19 (permalink) Old 09-04-2010, 08:15 AM
Install filters by feel rather than toque as dismantling becomes a problem. Have done several chnages on oil filters on bike and car , all on feel. So far no visible leakage and good.
Fastoman is online now
post #18 of 19 (permalink) Old 09-04-2010, 10:43 AM
MOST of the filters I do (car...) say to tighten till contact, then another 3/4 turn. I would NOT use a torque wrench on one.
post #19 of 19 (permalink) Old 09-07-2010, 09:39 PM
njd
I understand using a filter wrench for unscrewing, but I've ALWAYS tightened my oil filters by hand (with maybe a tiny bit extra force with the wrench)--and I've had no problems so far.
njd is offline
Similar Threads
Air filter dallasdon General Discussions - V-650 5 02-20-2015 08:10 AM
Air Filter RedRabbit Modifications - Performance - V-650 6 08-12-2008 11:21 PM
air filter jimstandinghorse Technical Discussion - V-650 12 08-01-2008 08:42 AM
DNA Air Filter invader Modifications - Performance - V-650 1 05-29-2008 03:39 AM
Oil and filter change dstarman Technical Discussion - V-650 1 05-08-2008 04:39 PM
