Larger Rear Tire? - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 06-29-2010, 07:24 PM Thread Starter
Larger Rear Tire?
Will a 160/55-17 fit on the Versys without any problems ?
REDBARON is offline
post #2 of 14 (permalink) Old 06-29-2010, 09:00 PM Thread Starter
I meant a 180/55-17 or 180/60-17
REDBARON is offline
post #3 of 14 (permalink) Old 06-30-2010, 12:20 AM
kevrider's Avatar
180 is too wide for the rim.
edit: read this short story about tire sizes.
Seal/CRAZY/misquoted
kevrider is offline
post #4 of 14 (permalink) Old 06-30-2010, 12:43 AM
post #5 of 14 (permalink) Old 07-01-2010, 06:29 PM Thread Starter
Thank you Guys
REDBARON is offline
post #6 of 14 (permalink) Old 07-01-2010, 06:54 PM
motojoe's Avatar
I'm so happy to see this posted. I've been wondering what will fit in that swing arm.
motojoe is offline
post #7 of 14 (permalink) Old 07-01-2010, 10:10 PM
cuff's Avatar
I fit a Shinko Advance 170/60 on the rear. The Advance's look to run a little flat to me and squeezing them onto the 4.5 rim fills them out pretty well. I took some rough numbers off the stock Dunlop with some calipers and they were almost the same. Shinko may have had some hight over the Dunlop but not much.
IBA# 38547
cuff is offline
post #8 of 14 (permalink) Old 11-20-2014, 03:57 PM
lacucaracha's Avatar
Sorry, I'm going to bump and hijack...
You can fit a larger tire but as mentioned above it will change the shape of the contact pattern. I just put some 170's on my V (like 2K ago) and they are noticeably twitchier than the OEM 160's.
I'd say if you want to put a bigger tire on get something like this: http://www.blueridgeperformance.net/brpwheelkits.html
And put a Ninja ZX-6R or 636 rim on it.
2014 Versys ABS
lacucaracha is offline
post #9 of 14 (permalink) Old 11-20-2014, 04:00 PM
also this: http://www.twfracing.com/zparts.html
Towards the bottom, but I'm confused why this does not include the center piece.
2014 Versys ABS
post #10 of 14 (permalink) Old 11-20-2014, 11:15 PM
It will work but not optimally. Handling quality will be diminished. If you wish to use a 180 tire and have it work as designed you need a wider rim.'
post #11 of 14 (permalink) Old 11-21-2014, 03:39 AM
It's also adds much undesired unsprung and spinning weight to the wheel.
post #12 of 14 (permalink) Old 11-21-2014, 07:36 AM
kohburn's Avatar
heck i went more narrow to a 150 (but taller) shinko its only 1/2" more narrow and you really can't see the difference.
kohburn is offline
post #13 of 14 (permalink) Old 11-21-2014, 09:57 AM
kballowe's Avatar
I have two friends that run a 150 and they say that handling is better.
kballowe is offline
post #14 of 14 (permalink) Old 11-21-2014, 12:10 PM
I've run rear Tourance 150/70 x 17 and like it. Right now I have a Kenda BIG BLOCK 150/70 x 17 on BIG RED, and it seems to corner pretty well (altho' I'm NOT trying to put a knee down....)!
