Advice needed - snapped gas tank tube - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 06-28-2010, 11:37 PM Thread Starter
mkay_m3's Avatar
So I'm reading I'm not the only lucky one with a snapped gas tank tube....
I was changing my plugs\filter on a newly acquired Versys, ran out of time and did not finish the job. Came back the next day to find my gas tank (that I oh-so-carefully secured the previous night) dangling on wires. The brittle plastic tube broke pretty close to its neck on the tank side.
So, what do people do in thess cases (short of forking over gazillion $$$ for a new pump) - did you replace the plastic tube completely with some machined aluminum tube, did you find some thin insert to go into the plastic tube and epoxy what is left of these broken tube OVER that insert OR did you use something OVER the epoxied pieces - some sort of a tube just to keep it safe? Should I be concerned with epoxy getting in contact with gas?
Thanks guys!
mkay_m3 is offline
post #2 of 8 (permalink) Old 06-28-2010, 11:48 PM
flienlow's Avatar
I think you might be But you should post a picture so the minds greater than mine can advise you. I'm thinkin' new pump.
flienlow is offline
post #3 of 8 (permalink) Old 06-29-2010, 12:21 AM
Post some pictures and might save your pocket some $$$
post #4 of 8 (permalink) Old 06-29-2010, 07:58 AM
Jake's Avatar
Now there might be a homeade fix, but when it comes to the fuel system on a bike i'm sceptical to use a rigged up part. Here is the fiche for the pump, If its the part i'm thinking of then its about $63. Could be worth it in peace of mind to replace it. I know i would, but order it from your dealer ron ayers is expensive on shipping.
http://fiche.ronayers.com/Index.cfm/...roup/Fuel_Pump
Jake is offline
post #5 of 8 (permalink) Old 06-29-2010, 08:29 AM Thread Starter
mkay_m3's Avatar
Don't have a pic at the moment - will post it up later. I've already looked at the diagram - unfortunately it's the pump that needs to be replaced as a whole assembly at @ $190 my cost. I wish I could just replace that $50 "tube-assembly" and be done with it.
mkay_m3 is offline
post #6 of 8 (permalink) Old 06-29-2010, 11:51 AM
flienlow's Avatar
+1 sorry! You'll need to bite the bullet on this one.
flienlow is offline
post #7 of 8 (permalink) Old 06-29-2010, 06:31 PM
Maybe you could replace the broken piece from a faulty fuel pump that had to replaced on a Versys, Ninja 650R or ER6. There are also some on Ebay:
http://shop.ebay.com/?_from=R40&_trk...All-Categories
invader is online now
post #8 of 8 (permalink) Old 06-29-2010, 08:20 PM Thread Starter
mkay_m3's Avatar
I think that's the answer - thanks Invader and to all who replied
mkay_m3 is offline
