K&N Oil Filter Question - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By outdoorgb
post #1 of 9 (permalink) Old 10-05-2015, 03:28 PM Thread Starter
K&N's website states that the KN-303 oil filter is the OEM replacement for my 2013. On Dennis Kirk's website they list a KN-204 and KN-303 as replacements. The 303 is longer then the OEM stock filter and the 204 is the same length. I purchased the KN-204 at Advanced Auto. Will it be alright to use this, or should I get the other one?
trapper is offline
post #2 of 9 (permalink) Old 10-05-2015, 08:08 PM
chadams66's Avatar
I've got the 303 on my bike..and it's the second one I've used...If the 204 fits it should be ok..length shouldn't be a big factor I don't think as far as operation is concerned...if I'm wrong hopefully someone will speak up and save you from a horrible mistake...
chadams66 is offline
post #3 of 9 (permalink) Old 10-05-2015, 08:22 PM Thread Starter
I ended up exchanging it for the 303. Better to be safe. I thought maybe someone here on the forum might of used the 204 without any issues.
trapper is offline
post #4 of 9 (permalink) Old 10-05-2015, 09:14 PM
Exclamation
K&N oil filters are now made in China by Champion Labs... The tacked on nut may cause the filter to leak, and they also tend to leak at the seal.
http://vfrworld.com/forums/showthrea...p-n-oil-filter
http://www.v-twinforum.com/forums/en...ver-again.html
http://www.st-owners.com/forums/show...-N-Oil-Filters
http://utahsba.com/forum/archive/index.php/t-29659.html
http://www.vfrdiscussion.com/forum/i...-filter-issue/
http://www.600rr.net/vb/90-oil-lube/...lter-leak.html
http://www.ducatimonster.org/forums/...l-seepage.html
http://www.triumphrat.net/tiger-1050...er-leaked.html
http://www.ducati.ms/forums/92-hyper...-problems.html
http://www.yamahasupertenere.com/ind...?topic=14709.0
http://www.my2wheels.com/forum/showt...il-Filter-leak
http://www.gixxer.com/forums/80-06-0...-heads-up.html
http://www.amazon.com/HP-1010-Perfor...ews/B000C3XD90
http://acurazine.com/forums/problems...ng-nut-893844/
http://www.iwsti.com/forums/2-5-lite...il-filter.html
http://www.dodge-dart.org/forum/dodg...il-filter.html
http://www.camaro5.com/forums/showthread.php?t=361023
http://re5rotary.proboards.com/threa...03-oil-filters
http://www.silveradosierra.com/vorte...k-t386425.html
http://www.gencoupe.com/2-0t-discuss...ing-loose.html
http://www.clubfrontier.org/forums/f...eaking-205026/
http://www.vtcoa.com/forums/f7/leaki...-filter-61771/
http://forums.nasioc.com/forums/showthread.php?t=438237
http://www.club3g.com/forum/3g-eclip...il-filter.html
http://www.bobistheoilguy.com/forums...&Number=321662
http://www.ls1gto.com/forums/showthread.php?t=28220
http://www.challengerforumz.com/thre...-filter.94229/
https://www.google.com/search?safe=s....0.NoRfOXMkxec
post #5 of 9 (permalink) Old 10-06-2015, 12:44 PM
IF you are going to use the K&N, one is just shorter than the other.
MOST of us get the longer one from whomever makes what we use....
EXTRA insurance, I guess.
post #6 of 9 (permalink) Old 10-06-2015, 01:06 PM
outdoorgb's Avatar
Invader...I'm going to need a little more evidence to believe your comment
invader likes this.
outdoorgb is offline
post #7 of 9 (permalink) Old 10-06-2015, 02:43 PM
The longer filters *should* have more filter media surface area - or filter to a lower micron level with a different media - in them when compared to the shorter ones.
More filter media surface area or different media *should* result in higher oil flow through the filter with less restriction over a longer period of time.
As the filter does it's job - filtering out solid particulate matter from the oil as it passes through the filter - the pressure drop across the filter with more area/different media *should* be lower over the same time period compared to the filter with less media.
Higher flow, less resisitance to that flow, lower pressure drop - for a longer period of time.
Given an option, use the larger filter. *IF* it has more or different, higher-performing media with more surface area, and filters to the same micron level.
visitor zero is offline
post #8 of 9 (permalink) Old 10-06-2015, 09:53 PM
Stud Muffin's Avatar
Crap I just put one on last night. Now I have to go check for a leaky nut.
P/S cover your exhaust pipe below the filter for removing it. Even with the bike level oil will drip on the pipes.
Stud Muffin is offline
post #9 of 9 (permalink) Old 10-07-2015, 12:14 AM
They also tend to leak at the seal.
You'd do better with one of these from Walmart:
http://www.walmart.com/ip/Purolator-...14610/19802834
http://www.walmart.com/ip/FRAM-Tough...ilter/16878945
http://www.walmart.com/ip/FRAM-Xtend...ilter/16879028
