Issue with the clutch? - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 10-04-2015, 08:27 PM Thread Starter
D3v
Hi.
I own an 08 versy with 32k on it. When im upshifting, the RPM's like to jump 1k for a split second before coming down. This happens when i change a gear when the engine is running at say 7500+RPM. Anything below 6000 rpm, the bike shifts fine. Is the clutch slipping or am I doing something wrong?
The clutch cable and chain are fine as far as adjustments are concerned.
thanks.
D3v is offline
post #2 of 9 (permalink) Old 10-05-2015, 03:08 AM
Try this... if you are at 5-6k rpm cruising in gear 5th or 6th gear and you twist the throttle hard does the RMPs increase/jump faster then you are accelerating = clutch slipping.
Gigitt is offline
post #3 of 9 (permalink) Old 10-05-2015, 03:31 AM Thread Starter
D3v
To make my explanation more clear, here is a vid of what happens (not mine)
https://www.youtube.com/watch?v=N1Yf-ZhIPzk.
D3v is offline
post #4 of 9 (permalink) Old 10-05-2015, 03:37 AM
hahahahaha that is called flat shifting!
hold throttle full and change gears as quick as you can with out reducing throttle when shifting
you need a quickshifter to fix that!
Healtech Quickshifter
HealTech Electronics Ltd. - Smart Tech for your Ride - QuickShifter easy (new)
Gigitt is offline
post #5 of 9 (permalink) Old 10-05-2015, 08:40 AM
Are you letting off the throttle when the clutch is disengaged (lever pulled in)?
ray h is offline
post #6 of 9 (permalink) Old 10-05-2015, 04:37 PM
Gigitt is right. If you are going to ride flat out all the time you need a quickshift.
post #7 of 9 (permalink) Old 10-05-2015, 07:55 PM
chadams66's Avatar
What if you only ride flat out..lets say 50% of the time? still need a quickshift? I like the slipper clutch option if you're going to ride flat out all of the time w/ the quickshifter of course...I believe there's a thread on the slipper around here somewhere...
chadams66 is offline
post #8 of 9 (permalink) Old 10-06-2015, 01:00 AM
OK well just going on the video the OP is causing the over rev by riding the way he does in the video.
Fix 1: Ride with less passion
Fix 2: Get a quick shift
post #9 of 9 (permalink) Old 10-06-2015, 03:33 AM
A quickshift allows for clutchless shifting at full throttle acceleration.
Healtech Quickshift allows for full and also partial throttle acceleration.
check out the videos on the page I linked above. there is a video of Versys 1000 on a dyno demonstrating it.
If you are riding like in you initial video, then you need to learn your clutch lever action and shift with partial clutch pulls while loading up the gear lever by lifting your toes, a quick partial pull of the clutch and the gear will slip in.
It is all in the timing of unloading the engine from the gearbox... just like what a quickshift does by electronically detecting a shift and momentarily interrupting the ignition.
Gigitt is offline
