Accessory leads -no power? - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 10-02-2015, 03:43 PM Thread Starter
No power in accessory leads.
I bought an Oxford dual USB socket and installed it in the left side accessory plug socket. I found the spare accessory leads under the cover beneath the windshield but there is no power to them. I wanted to connect the USB to these so that it does not drain the battery while the bike is not in use. I tried connecting to the battery directly but found that the LED light in the socket is always lit.
I looked at the directions from Kawasaki on installing a 12v DC charger and they are shown here. https://www.kawasaki.com/Content/Upl..._999940485.pdf
Anyone have any ideas on how to get power to the accessory leads?
BTW.... I have the Versys 650LT. The hand protectors do not give enough clearance for using the USB or Charging socket. I bought a right angle adapter for the USB which solved the problem.
LaloF is offline
post #2 of 5 (permalink) Old 10-02-2015, 03:59 PM
sharrison56's Avatar
Are there any missing fuses in the fuse box? Maybe they don't put them in unless you have it installed at the dealer.
Steve
Now I have four!
sharrison56 is offline
post #3 of 5 (permalink) Old 10-02-2015, 04:41 PM
Maybe you need to install the OEM relay? Per Kawasaki, it's a required component for installing the accessories like the 12v socket or gear indicator.
https://www.kawasaki.com/Accessories...FFFA/999940556
scutrbrau is offline
post #4 of 5 (permalink) Old 10-02-2015, 06:11 PM
Wulff81's Avatar
Must have the relay. I learned that one the hard way myself. It mounts right behind the instrument cluster.
Wulff81 is offline
post #5 of 5 (permalink) Old 10-03-2015, 01:51 AM
look at this write up. this will answer your question.
http://www.kawasakiversys.com/forums...t-install.html
Motojunkee is offline
