Chain oilers? - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By kevrider
post #1 of 15 (permalink) Old 09-25-2015, 08:18 AM Thread Starter
BEACHBUM's Avatar
Chain oilers?
Does anyone use one of these chain oiler systems? If so,what is your opinion.....
BEACHBUM is offline
post #2 of 15 (permalink) Old 09-25-2015, 08:24 AM
I'm interested as well...
2008 Red Kawasaki Versys - Purchased 7/12/2015
NilesStonne is offline
post #3 of 15 (permalink) Old 09-25-2015, 09:21 AM
kohburn's Avatar
am I missing something? did you post a specific system? or are you just asking if anyone uses ANY auto oiler?
I have a motobriz oiler. it functions ok in warm weather. there are much better systems though.
PDOiler Mini Parts
LoobMan Motorcycle Chain Oiler Loobman chain-oiler - Shop
Auto2 - Deluxe Kit
I commute every day rain or shine and my bike lives outside so I don't have time for daily chain maintenance. With the auto oiler I just wipe the dirt off the chain at every oil change or tire change. I run a 50/50 blend of wd40 and gear oil.
kohburn is offline
post #4 of 15 (permalink) Old 09-25-2015, 12:45 PM
I have vacuum operated Scottoilers on several bikes. Work good.
waltermitty is offline
post #5 of 15 (permalink) Old 09-25-2015, 07:13 PM Thread Starter
BEACHBUM's Avatar
I was asking a general question about oilers...I should have stated that.
Webbike World has a review on a very basic Cobrra Nemo I thought interesting, my education on chains is ongoing.
BEACHBUM is offline
post #6 of 15 (permalink) Old 09-26-2015, 01:30 AM
kevrider's Avatar
i have a loobman on the versys, it gets the job done. my recent trip must have covered about 3000 miles, hardly made a dent in the reservoir volume. fiddly to install, but simple to operate and i like that it doesn't tap into the motor. i had a scottoiler on the old transalp, one seems to work as well as the other. i fill the res with chainsaw oil. these things are great for touring. there was a lot of road construction in ID-MT-WY where the bike gets covered in dust and muck. i was happy to have that oiler installed.
here a review on another interesting option.
BEACHBUM likes this.
Seal/CRAZY/misquoted
kevrider is offline
post #7 of 15 (permalink) Old 09-26-2015, 04:06 AM
kawdog's Avatar
What I don't understand is how the constant oilers don't make a mess on garage floors. I clean and lube mine about every 2 or 3 days, and it still has a few spots here and there. When I had an oem gravity feed oiler on my Norton Commando 750, I had to stick a screw in it because my whole back end was covered in oil.
I would like to see garage floors well lit around where one of those bikes are parked. It's just hard to believe they don't dribble on the floor at night
kawdog is offline
post #8 of 15 (permalink) Old 09-26-2015, 06:31 AM
kevrider's Avatar
the loobman is not a constant feed. you open the valve to allow a small amount into the tube, which slowly makes its way to the chain. when it's done, it's done, until you send another slug of oil into the tube. a small amount is good enough for an all day ride and will coat the chain before you stop for gas. there is no flow at the end of the day. the same amount for my 5-mile commute might lube the floor, so i don't do that.
kevrider is offline
post #9 of 15 (permalink) Old 09-26-2015, 08:18 AM
I run a Pro-Oiler
Love It!
Controller LHS of dash - bottle behind LHS faring:
I made an acrylic bottle holder:
Bottle and pump:
Sprocket nozzles:
The Brain:
Gigitt is offline
post #10 of 15 (permalink) Old 09-26-2015, 05:59 PM
Gigitt - NICE! I did something similar many years ago, using a 'Loobman' and a 12v windshield washer pump. Worked OK, then I switched to using ONLY WD40, and removed the Loobman 'stuff'.
post #11 of 15 (permalink) Old 09-26-2015, 07:39 PM
kawdog's Avatar
That's one clean windshield! Do you use Windex?
kawdog is offline
post #12 of 15 (permalink) Old 09-26-2015, 07:47 PM
Plexus - perspex polish and cleaner :P
Gigitt is offline
post #13 of 15 (permalink) Old 09-26-2015, 09:42 PM
kawdog's Avatar
What kind of wind screen do you have? I didn't think you had one!
kawdog is offline
post #14 of 15 (permalink) Old 09-26-2015, 09:59 PM
I commute without one,
but use Madstad 20in Sports screen
Gigitt is offline
post #15 of 15 (permalink) Old 09-28-2015, 09:15 AM
kohburn's Avatar
if you are super budget minded you can make your manual auto oiler own for pennies.
all you need is a bottle reservoir, a small engine primer bulb, some tubing, and pick the style of oil delivery fitting that you want.
each time you ride you just hit the primer bulb and the oil makes its way down to the chain.
the motobriz uses a sort of felt pad that gets damp and the chain rides over it picking up the oil.
several use a one or two sided fine metal or plastic tube that places oil on the sides of the rear sprocket,
and one uses a string braid that hangs down form the swing arm and rides on the top of the lower chain.
you shouldn't get drips in the garage from most of them because the oil delivery should be very slow measured on drops per applied to the entire length of chain per mile.
kohburn is offline
