chain clean with Seafoam? - Kawasaki Versys Forum
Like Tree8Likes
post #1 of 43 (permalink) Old 09-23-2015, 07:07 PM Thread Starter
I do not want to use WD40, but I have a can of Seafoam. Is that effective and is it safe to use for the chain?
Todd
White 2015 650 LT
Apple Valley, Minnesota
Squishman is offline
post #2 of 43 (permalink) Old 09-23-2015, 07:21 PM
I wouldn't try it...If you don't want to use WD-40. Then give Goop Hand Cleaner a try with a Grunge Brush. Thats what i use. just the regular Goop not the one with Pumice in it...
!BcKEoKQ!2k~$(KGrHqYH-CgEqu!U6SwdBKzQDZyeHQ~~_35 by weljo2001, on Flickr
post #3 of 43 (permalink) Old 09-23-2015, 09:38 PM
WD40 works great.
kballowe likes this.
08' Versys
HAWKSHOT99 is offline
post #4 of 43 (permalink) Old 09-23-2015, 11:24 PM
I just wipe the chain off with a rag before lubing it with Maxima Chain Guard which doesn't gum it up... This might work:
DuPont Motorcycle Degreaser, 11 oz - Walmart.com
post #5 of 43 (permalink) Old 09-24-2015, 12:19 AM
kawdog's Avatar
Any solvent especially OR chain lube should say made for x and o ring chains to not take ANY chances. Chains, sprockets, and labor/your time is expensive.
Chain cleaning and lube is a fast fine art of motorcycling: it's your main constant maintenance. Don't screw it up experimenting blindly by asking web opinions. You better have verifiable proof on every can!
Of course if you are a Chemical Engineer in the petroleum industry, never mind
kawdog is offline
post #6 of 43 (permalink) Old 09-24-2015, 03:20 AM
use Kerosene (also known as Parafin) on a rag and wipe the chain.
Then use what ever chain lube to protect and lube your chain.
I have a chain oiler and never have to clean the chain - but I do prefer to clean it once in a while and use kerosene. Does not take much on a rag and chain comes up nice and clean.
I also use WD-40 as a cleaner and degreaser all over the bike except the brakes
Removed stubborn road tar quickly.
Gigitt is offline
post #7 of 43 (permalink) Old 09-24-2015, 09:09 AM
kballowe's Avatar
Originally Posted by HAWKSHOT99 View Post
WD40 works great.
Yes, it does.
And it's harmless to the chain and most other stuff.
Kerosene is faster. Diesel fuel works as well.
NO SMOKING !!!
kballowe is offline
post #8 of 43 (permalink) Old 09-24-2015, 01:49 PM
kohburn's Avatar
seafoam has too many solvents in it I would not use. wd40 is much more harmless than seafoam.
kohburn is offline
post #9 of 43 (permalink) Old 09-24-2015, 05:11 PM
kawdog's Avatar
Someone here got 50k miles on a chain using wd40 in a chain oiler said it got real loud near the end (like the rubber rings were gone) and that's the main reason they finally replaced it.
I bet wd40 does not say safe for x and o ring chains on it ymmv
kawdog is offline
post #10 of 43 (permalink) Old 09-24-2015, 06:44 PM
MIGHT be ME on my '08 in AZ, tho' I did NOT use it in an oiler. The ORIGINAL chain (ONLY ever 'lubed' w/ WD40!) was changed at 57,xxx MILES, then inspected by "watt-man", an engineer, who said that there was only ONE noisy link, and that, otherwise, it was STILL good for MANY more miles!
BTW - I did NOT say it "...got real loud near the end...". I said I changed it because it was becoming noisy.
post #11 of 43 (permalink) Old 09-24-2015, 07:17 PM Thread Starter
Good info. Thx for the responses. I won't be using seafoam. I do have a Grunge Brush that is still in the packaging. I wonder if you can buy small containers of kerosene. Like a pint.
Todd
White 2015 650 LT
post #12 of 43 (permalink) Old 09-24-2015, 08:55 PM
kawdog's Avatar
Well, it may not be you then. If we have another one, we will have enough for a statistical sample to measure the variance of averages
kawdog is offline
post #13 of 43 (permalink) Old 09-25-2015, 07:02 AM
kohburn's Avatar
I don't live life requiring manufacturers to spell out every single potential function of a product. I work off MSDS sheets, tests, and evidence.
kohburn is offline
post #14 of 43 (permalink) Old 09-25-2015, 07:05 AM
kohburn's Avatar
"lamp oil" at the hardware store, home fuel oil, kerosene. all essentially the same. according to some in the industry they are exactly the same these days except for dye additives for tax purposes.
Squishman and Ididar like this.
kohburn is offline
post #15 of 43 (permalink) Old 09-25-2015, 08:04 AM
seafoam goes in the gas tank not the chain, WD-40 is great for the cleaning and lubeing of the chain, if you dont wanna use it to lube it it still can be used for cleaning, spray the chain down lightly then wipe off, thats what i do on all of mine ,
post #16 of 43 (permalink) Old 09-25-2015, 08:29 AM
Wulff81's Avatar
Kerosene should be in the paint chemical section of the local hardware store.
Wulff81 is offline
post #17 of 43 (permalink) Old 09-25-2015, 10:42 AM
GiantAntCowboy's Avatar
"Is it ok to lube my chain with WD-40?"
Haha!
kawdog likes this.
2008 Versys 650
Been riding 8 or 9 years, and have owned 8 or 9 bikes; its an addiction I can't quit...
GiantAntCowboy is offline
post #18 of 43 (permalink) Old 09-25-2015, 10:50 AM
Haha!
thats not lubed with WD-40 thats the bike got soaked in WD-40 xD
must be MR.eddie
post #19 of 43 (permalink) Old 09-25-2015, 11:47 AM
kawdog's Avatar
What in the world does Material Safety Data Sheets have to do with wearing out the rubber ring seals drying out due to chemical interfaces in a chain? Nothing: they are mutually exclusive. They are not flammable, combustible, or chronic hazards.
So at least with your MSDS sheets, you know you are not flammable, combustible, or a chronic hazard sitting by itself alone. But if you got MSDS sheets for EVERY material interface possible, THAT would be warehouses full of MSDS sheets. I think looking for applicable use on solvent and chain lube cans is slightly easier. ymmv
If you publish any of your tests and evidence, I'd like to see your lube, solvent, o and x ring chain interaction data for every type solvent and chain lube possible or ANY that you have would be sufficient.
kawdog is offline
post #20 of 43 (permalink) Old 09-25-2015, 11:52 AM
kohburn's Avatar
that's a fuel line failure, but the humor is not lost on me
kohburn is offline
