Help with the math please - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By saddlebag
post #1 of 14 (permalink) Old 09-22-2015, 05:44 PM Thread Starter
Returned from a 12,000 k tour on the 2015 LT. Can someone help me understand the numbers. Kawasaki claim 5 more HP over my '08 but I cruise at 120 kph at 6000 RPM on the 15 and the '08 was at 5600 RPM. Both speedos are off by 6%. Yet the fuel mileage on the 15 is far better than the '08. Is it engine mapping? And where are the extra 5 ponies? Thanks
tonyV is offline
post #2 of 14 (permalink) Old 09-22-2015, 09:40 PM
kawdog's Avatar
>hp + >rpm = >mpg
Good observations!
kawdog is offline
post #3 of 14 (permalink) Old 09-22-2015, 10:11 PM
Originally Posted by kawdog View Post
The 2015 also has an advanced ignition system, more weight, and/or possible gearing changes to accommodate the ignition system change which may account for most of that variance.
Ignition system is unchanged, although the ignition switch position has been changed to accommodate the new instrument cluster.
NEW One-piece exhaust and muffler helps to boost top-end performance.
NEW Fuel pump for improved fuel delivery.
NEW Revised ECU settings to match exhaust updates and enhance fuel economy.
NEW KAMS (Kawasaki Air Management System) radiator air ducting system.
NEW Adjustable and larger windshield provides a large still-air pocket for comfort...
post #4 of 14 (permalink) Old 09-23-2015, 01:54 AM
Thanks fr the up date Invader.
post #5 of 14 (permalink) Old 09-23-2015, 03:35 AM
You sure about that? Mine does 126 kph at 6000 RPM. So 120 kph is at ~5700 RPM, right about where it apparently was on the old one.
2015 Versys 650
_Big_Mac_ is offline
post #6 of 14 (permalink) Old 09-23-2015, 01:55 PM
The '15 ALSO has an oxygen sensor, so it's NOW a closed-loop system, which MIGHT explain better gas mileage. MY experience also shows that the APPARENT speedo error is LESS than on older Vs.
For instance, on the '09 it showed 22km/hr (14 mph) per 1,000 rpm on the tach, while my '15 shows 21km/hr (13mph) per 1,000.
Also, the HP seems to be HIGHER in the rev range now.
post #7 of 14 (permalink) Old 09-23-2015, 02:51 PM
? My 2012 has an O2 sensor
post #8 of 14 (permalink) Old 09-23-2015, 02:52 PM
Indicated speed to actual speed ratio will vary depending on ambient temperature, and also depending on which rear tire is used and its wear.
post #9 of 14 (permalink) Old 09-24-2015, 04:35 AM
Does it also have an O2 sensor in the exhaust? The new one does.
2015 Versys 650
post #10 of 14 (permalink) Old 09-24-2015, 06:49 PM
That's BECAUSE you're NOT in Canada or the USA.
OEM Dunlop rear, and I did NOT talk about ACTUAL speed, just comparing INDICATED speed vs rpm.
post #11 of 14 (permalink) Old 09-25-2015, 08:14 AM Thread Starter
thanks to all for the feedback and info. " Invader's" comments ring true. The 2015's aero package shone in a variety of wind conditions, especially 40 mph crosswinds in Kansas. I was expecting a Puig windscreen to be waiting for me when I returned to Canada, however only an " out of stock" email and a refund from Amazon were waiting. Tried emailing Madstad regarding their new screen and like many others on the forum.....no response. May wait til spring when there are more options. Cheers.
tonyV is offline
post #12 of 14 (permalink) Old 09-25-2015, 01:02 PM
saddlebag's Avatar
The problem is that people who dyno bikes give "peak" numbers instead of "total" numbers. The new bike may make a greater "peak" number but be less powerful overall.
Torque is another dumb thing they like to show. In itself, torque is meaningless. It only has meaning at a particular rpm...which is the power. Torque is superfluous.
In any event, power may have no meaning at all in how you are looking at it. The gearing could be completely different between the two bikes. And even if they were the same, they will both require the same power to travel at the same rate of speed, all else being equal. The difference would be that you may not need to turn the throttle as far on the more powerful one to get there. Don't confuse that with requiring less gas. It may be 10% more powerful than the old design and use 100% more fuel. The power being measured is the output power, not the input power from the fuel. To know that would require knowing the efficiency of the engine at every rpm.
MrKneeDropper likes this.
saddlebag is offline
post #13 of 14 (permalink) Old 09-25-2015, 01:11 PM
ronheater70's Avatar
According to my Tack and Speedo, I hit 70 MPH somewhere around the 5200 range
SO is that the Average?
ronheater70 is offline
post #14 of 14 (permalink) Old 09-25-2015, 01:26 PM
Yes.
