My suspension setup on 2015 650LT - FYI - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 09-13-2015, 09:09 PM Thread Starter
claggie's Avatar
Post My suspension setup on 2015 650LT - FYI
I have a new 2015 Versys 650LT with about 500 miles on it now. I have adjusted the suspension over several rides on my favorite spirited canyon carving road and here is where I ended up. This is just a reference - your mileage may vary.
Specs w/ solo rider:
Solo rider: 202 lbs. with hard cases (empty), tank bag and tail bag
Read sag: 4 clicks from softest gives me 1.5 inches sag
Front preload (left fork): 2.75 turns out from softest setting, gives me 1.5 inches of sag and push down test of "zip tie at half travel" with cold fork oil; after spirited ride, zip tie is at 3/4 full fork travel
Front tension (right fork): 2 turns out for softest feels good
Specs w/ 2 riders:
Passenger rider: 140 lbs.
Read sag: 16 clicks from softest gives me 1.5 inches sag
All front fork settings I have left as is for now. No detriment felt in handling of bike.
Rear sag adjuster estimate: Based on my solo and 2-up rider settings, I think the stock rear shock set in the softest setting would hold ~150lbs. Then, every click toward the "hard" setting is equal to about 15lbs. I'm 210 and using 4 clicks from softest and with my 2-up, we are 350 lbs. total using 16 clicks from softest.
Pictures:
1) Front Sag with Solo Rider (1.5 inches of travel)
2) Front Sag with Full Push Down Test (1/2 fork travel)
3) Front Sag after Spirited Ride (3/4 fork travel)
Chris
2015 Versys 650LT, White
claggie is offline
post #2 of 3 (permalink) Old 09-13-2015, 09:23 PM
I was messing with mine last week, ended up cranking everything almost up to the max, a little less tension. If I have to stop I really have to stop, are you finding too much nose dive when riding just your self?
I'm probably going about the whole thing wrong. I don't care about bumps or comfort, just keeping my ass off the road and maximizing braking power. Any suggestions?
Modake is offline
post #3 of 3 (permalink) Old 09-13-2015, 09:30 PM Thread Starter
claggie's Avatar
I did one semi-aggressive brake test and the zip tie didn't exceed the 3/4 mark. I wanted to make sure the forks wouldn't bottom out.
Depending on your weight, I would assume your setup is way too stiff. My understanding is that the accepted street riding norms are ~1.5 inches of rear and front sag. The tension is a personal setting.
My setup feels great and the bike handles like it is on rails. My riding style is fairly conservative with me going about 40-50mph in a posted 30mph turn if that helps.
Good luck and keep us posted.
Chris
claggie is offline
