Relay Help - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 06-19-2010, 02:33 PM Thread Starter
Relay Help
Hello,
I bought a cheap 12 volt relay to use for my fog lights and GPS power. I had it wired to the battery with a switch installed for on/off. I installed the relay and the next time I went to ride the battery was dead. I assume I have the positives wrong but I have attached a pic of the relay box. If anyone is also to tell me where each wire goes and I'll see if I have it hooked up wrong. The stuff written on the box was there, I'm not sure what it means.
If the pic is poor the top line says 85, 87a & 87 bottom line is 86 & 30.
I have to look again but I think I have:
85-ground
86- battery
30- foglights, gps
either 87a or 87 is wired into the ignition.
Blue 2008, mirror extenders, Givi windshield, side sliders (came with bike), seat mod, 16T front sprocket, Ram GPS mount.
I work weird hours, if I don't reply, I will eventually, depending on the schedule. Also Ham operator VE5PS.
krbuc is offline
post #2 of 9 (permalink) Old 06-19-2010, 02:35 PM Thread Starter
Do I need to switch the positives? 30 to battery and 87 to fog lights, gps?
krbuc is offline
post #3 of 9 (permalink) Old 06-19-2010, 02:57 PM
Lours_Polaire's Avatar
Take a multimeter and with the continuity probe, check the common terminal
Then, when those common have being determine, you will probably have 1 (out of 5) connector that will not be related to another
After that, with the multimeter, check resistance on the terminal, you will find resistance on the coil side of the relay, not on the others
As far as the lonely terminal, I would assume that it is the opposite contact (open - close) of the contact side of the relay
Hope it helps !
PS If you don't have a multimeter, well this response was useless ...
LOP
Lours_Polaire is offline
post #4 of 9 (permalink) Old 06-19-2010, 03:03 PM Thread Starter
I was hoping someone else would do that work for me and just tell me what to do with each pin I have to go to work soon and will have to play around with it tomorrow. For now I just unplugged the relay and the battery is fine.
If anyone has an answer like _____ wire goes ______? then let me know, otherwise I will play around with it later.
krbuc is offline
post #5 of 9 (permalink) Old 06-19-2010, 03:12 PM
OK ...
So I look at the pic after my previous response
Now
Sorry ... Can't see the number on the pic
If you have hook the P and the G terminal directly to you battery, no switching of any sort in between, for sure you drained the battery, this is the coil side of the relay and as soon has the circuit loop is close (both terminal connected to a source) , current goes thrue it, hence draining the bat.
If not, the R terminal is the one that's going to feed voltage to the other terminal of the relay (two top row terminal on the right of the picture)
As you can see on the pic, one side is normaly close/on (current goes thrue - on the left side) and the other is normaly open/off (no current - on the right)
If you activate the coil side, it will change from it's normal state (left terminal close and right terminal open) to (left terminal open and right terminal close)
So you have to manage those state to get what you want
This might not be what you need as far as relay goes for the application you want to use it for, but it can be done with a bit on planing
Hope this was usefull
LOP
post #6 of 9 (permalink) Old 06-19-2010, 03:42 PM Thread Starter
Yes, that makes sense, I was just rushing through and not thinking enough about it I guess.... The first clue should have been, when I plugged in the relay it clicks. hmm something just clicked and the ignition was off.... maybe there is power there?
Not that it helps cause you cant see the numbers but I have:
30 & 87 to the lights & GPS (hooked together)
86 to ignition
87 the battery (+)
85 to ground
Guess what????? does not click unless the ignition is on and it's all working. Guess I need to learn to slow down and do things right, one of these times I'll fry the whole electrical system. "Slow and steady wins the race"
krbuc is offline
post #7 of 9 (permalink) Old 06-19-2010, 04:42 PM
healdem's Avatar
http://www.offroaders.com/info/tech-...ive-wiring.htm
pin 30 is +12v from Battery
Pin 87 is +12v to accesories.... in your case lights + GPS
pins 85/86 are from the sense circuit to the chassis ground, doesn't matter but 85 ideally sense circuit (either switch or wire into the desired circuit such as the tail lights/ side lights/running lights/headlights etc)
ideally 86 to chassis ground
healdem is offline
post #8 of 9 (permalink) Old 06-19-2010, 05:09 PM
+1 to Healdem. I just connected a second horn using the same wiring sequence. Works fine.
ScottyNeal is offline
post #9 of 9 (permalink) Old 06-20-2010, 08:09 PM Thread Starter
appears to be good now, i have changed it to how healdem said.
krbuc is offline
