help - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 06-19-2010, 01:18 PM Thread Starter
help
Hi guys,just bought a 07 versys can someone please tell me what the light is for at the right hand side of the abs light ? it says FL ,it comes on when you turn the ignition on and stays on, ive done a search but cant find anything, thanks .......kev
strada is offline
post #2 of 13 (permalink) Old 06-19-2010, 01:43 PM
healdem's Avatar
sounds like its the Fuel Injection Light (if its red)
if the light is always on (it should go off after 2..3 seconds (after the rev coutner completes its test cycle) then there is a fault on the fuel injection system
look a the service manual section 3-20 to trouble shoot what the fault is.
you need to download the service manual there's a URL somewhere on this site
healdem is offline
post #3 of 13 (permalink) Old 06-19-2010, 02:03 PM Thread Starter
cheers if its a faulty fuel injection system wont the the bike be running rough ? Went out on it today and it runs fine. it does have a carbon end can on it ,would that have anything to do with it ? The last owner didnt have any manuals and for some reason i cant download them from here, i just get a network error message,
strada is offline
post #4 of 13 (permalink) Old 06-19-2010, 04:09 PM
healdem's Avatar
No
its a fault on the fuel injection system
there's a sensor somewhere that is out of whack
that's why I'd suggest you either take it into a dealer or get the fault code yourself and work out what you want to do
http://www.filesend.net/download.php...1668d621e9a5a6
http://www.kawasakiversys.com/forums...service+manual
healdem is offline
post #5 of 13 (permalink) Old 06-19-2010, 04:14 PM Thread Starter
Looks like a trip to the dealer then ive only had it 2 days and this happens LOL, thanks for your time ,
strada is offline
post #6 of 13 (permalink) Old 06-19-2010, 06:49 PM
Sounds like it could be your O2 sensor... You can read the FI trouble codes yourself:
Under the seat, along the right sub-frame rail is an orange/black wire with a bullet connector. This is the self-diagnosis terminal. In order to read out the CURRENT Service Codes (MODE 1), ground that wire with the KEY ON. The FI light will begin to flash codes. There will be a 5 second delay and then the codes begin. The first flash is always a LONG (1 sec) followed by either LONG or SHORT (0.5 sec) flashes. LONG flashes indicate TENS and short flashes ONES. One LONG followed by two SHORT = 12. Two LONG, one SHORT = 21. Three LONG, two short = 32, etc. There is an interval of 1.5 seconds between TENS and ONES. There is a 3 second interval between codes.
CODE Malfunction-
11_______ Main throttle sensor
12_______ Inlet air pressure sensor
13_______ Inlet air temperature sensor
14_______ Water temperature sensor
21_______ Crankshaft sensor
24 & 25___Speed sensor (24 then 25, repeatedly)
31_______Vehicle-down sensor
32_______Subthrottle sensor
33_______Oxygen sensor inactive (Europe)
51_______Ignition Coil #1
52_______Ignition Coil #2
56_______Radiator Fan Relay
62_______Subthrottle valve actuator (sensor in range but not responding)
64_______Air switching valve
67_______Oxygen sensor heater (Europe)
94_______Oxygen sensor out-of-range
To recover codes set in memory (MODE 2); KEY ON, touch the self-diagnosis terminal rapidly to ground more than 5 times within 2 seconds. The lead must remain grounded (after 5 groundings) for the remainder of the diagnostic session. The codes will readout exactly as in MODE 1.
To clear codes from the ECU,, pull the clutch in for more than 5 seconds.
Things the ECU cannot detect:
FI light
Fuel Pump
Fuel Pump Relay
DFI Main Relay
ECU Power and Ground
Fuel Injectors
post #7 of 13 (permalink) Old 06-19-2010, 06:55 PM
naz
naz's Avatar
Do you work for kawasaki invader? just a thought
naz is offline
post #8 of 13 (permalink) Old 06-19-2010, 07:31 PM
Invader knows his s**t!!! I am always amazed at what an exact and precise answer he gives!!!
I can see a new thread---"Just ask Invader"
Thanks for all the great info, I'm starting a note pad with all this info-quicker than serching the manual.
2009 Lime green Versys
Hepco & Becker crash bars
Givi side carriers w/ E21's
Fenda Extenda
cut tail fender
black lower panels
Sw-Motech 20mm riser
Randy49 is offline
post #9 of 13 (permalink) Old 06-19-2010, 11:49 PM
Your Honor, I second the above...
This forum has it All and it rocks....
post #10 of 13 (permalink) Old 06-21-2010, 08:29 AM Thread Starter
Ok guys,done the test and im getting 62 ( subthrottle valve actuator )
i have had a look in the service manual but i think i will leave it to an expert
since i dont even know what it does or what its meant to do spoke to my local dealer and he can only fit me in ,in 3 weeks time
Would it be ok to carry on riding the bike as it still seems to be running fine ?
or could i make thing worse,
strada is offline
post #11 of 13 (permalink) Old 08-15-2011, 08:29 PM
same error code
i just finished changing my sparkplugs (09 with 13000 miles)
and I go to start the bike up at it:
1. Starts rough
2. FI light stays on
I did the diagnostic code thing, and got a code 62.
did I forget to connect a sensor during the re-assembly of the airbox area after i did the plugs.
I do not think I left any out, but I guess I did soemthing.
any help would be greatly appreciated.
I want to ride.
jbria is offline
post #12 of 13 (permalink) Old 08-15-2011, 08:57 PM
sharrison56's Avatar
The first time I did mine I forgot to connect the plug on the right side of the airbox. I think it is the air temperature sensor.
Steve
Now I have four!
sharrison56 is offline
post #13 of 13 (permalink) Old 08-16-2011, 04:03 AM
Clear the code by disconnecting battery for a few minutes, and make sure your battery is fully charged. If subthrottle valve actuator still doesn't cycle properly when turning ignition on: Disconnect subthrottle sensor (upper black TPS), turn ignition on for at least 4 seconds, turn ignition off, reconnect subthrottle sensor and clear the codes again by disconnecting battery. Reconnect fully charged battery and see what happens.
