Lube Rear Brake Joint Pin - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 06-11-2010, 01:44 PM Thread Starter
tebbert's Avatar
Periodic maintenance in the service manual states the "Rear Brake Joint Pin" needs greased. Can someone help me identify where the "pin" is? Is it referring to the rear brake lever or the brake caliper?
tebbert is offline
post #2 of 10 (permalink) Old 06-11-2010, 02:45 PM
dakotav899's Avatar
The only thing I could find is the pivot shaft, of the rear brake pedal...and thats when you install it...according to the manual.
08 Versys
97 Suzuki DR350
Pro Grip tank protector
Wee Strom hand guards
Nelson Riggs Soft Bags
Xelement Black mini tank bag
Xelement Silver ignitor Tri-Tex Fabric and Mesh Jacket with armor
Xelement Advanced silver and black Fabric Pants with level 3 armor
12V Powerlet
Nuvi 550 GPS
Yoshimura TRC slip on (stainless)
dakotav899 is offline
post #3 of 10 (permalink) Old 06-11-2010, 06:52 PM
naz
naz's Avatar
i believe this is
i changed the pads lately and i noticed the grease existence under the rubber seal there.it makes sense cause it moves forward and back on the axle constantly while using the brake.the ,left,other is sealed.
(left and right of hydraulic piston)
naz is offline
post #4 of 10 (permalink) Old 06-11-2010, 09:32 PM
StonedGP's Avatar
I do believe this is it. The pads slide on it
StonedGP is offline
post #5 of 10 (permalink) Old 06-11-2010, 09:40 PM
I'd be careful lubing anything that is that close to the brake pads. The back
brake is weak as it is, with grease, no brake.
post #6 of 10 (permalink) Old 06-14-2010, 11:26 AM
naz
naz's Avatar
Originally Posted by naz View Post
i believe this is
stoned is correct .
the pin is the small one and it sure needs grease.havent anybody else seen grease in the green circles in the above attachment?mine sure has grease under the plastic seals.i was trying to show this in the image but the parts picture makes it crystal clear.
naz is offline
post #7 of 10 (permalink) Old 06-16-2010, 08:55 PM
Those are the slider pins, and they need to be clean and greased. The pad retaining pin (red circle) should NOT be lubricated.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #8 of 10 (permalink) Old 06-17-2010, 03:31 AM
naz
naz's Avatar
the pad retaining pin (red) may rust.the pad retaining pin also guides the pads while braking.service manual refers to it and definately says to grease it.my opinion is to grease it .about the slider pins (green),one is sealed and the other can be cleaned and lubed.
naz is offline
post #9 of 10 (permalink) Old 06-17-2010, 03:55 AM
Sorry no offence meant.
Please tell which pin to grease-RED OR GREEN OR BOTH
Fastoman is online now
post #10 of 10 (permalink) Old 06-17-2010, 02:32 PM
naz
naz's Avatar
red ->clean +grease
green->clean+grease
thats my opinion
naz is offline
