Chain maintenance - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 06-10-2010, 11:00 AM Thread Starter
Cruiseman's Avatar
Chain maintenance
How do you care for your chain? How often to lubricate? How often to adjust? I have not had a chain-driven bike in quite a while.
2010 Versys - 2007 Honda Goldwing
Cruiseman is offline
post #2 of 18 (permalink) Old 06-10-2010, 11:09 AM
objectuser's Avatar
Lots of discussion about using that DuPont teflon stuff. Search for DuPont and I think there are a couple of threads. I bought some, but have only used it once.
objectuser is offline
post #3 of 18 (permalink) Old 06-10-2010, 11:17 AM
naz
naz's Avatar
poor guy welcome to the superiority of chain driven bikes...
i clean the chain using kerosene with a small soft paint brush.then i wipe it, wait to become dry and then spray a specific chain lube of my choice(loctite brand atm).in my other bikes i always did the same procedure ,chains always lasted for about 25-30 k kilometers.i repeat the procedure every 300-400 km
i used a motul chain lube spray but it was very glue like and the chain become like concrete very fast.then i used a valvoline spray that leaves a clear distinctive white film on the chain.i liked the film but after 3-4 cans i figured out that this product offers only psychological peace
now i try the loctite brand special chain lube ,its thinner than motul and offers equivalent lube .i have also tried some teflon based brands .just buy a specific chain lube product and repeat this simple procedure.dont exaggerate cause the chain will expand faster if you lube it every day.
i have also tested the wd 40 method and i can say it works,you just need to spray the chain more often.
the interval of spraying is a subject of change due to weather/climate condition and riding areas.rainy,dry,off road use,gravel etc.
hope i helped
naz is offline
post #4 of 18 (permalink) Old 06-10-2010, 01:02 PM
I, and many other here, have had very good luck using this
http://www.amazon.com/DuPont-Performance-Lubricants-Multi-Use-Fluoropolymer/dp/B000GL19TY
It is available at Ace Hardware, and Lowes building supply.
It keeps the chain and bike very clean, and keeps the chain lubed and quiet. I lube every 400 miles, or after riding/parking in the rain. I use it to clean as well as lubricate. There is a huge thread on this site on this subject. Do a search.
See your owners manual for chain adjustment. A little loose is better than a little tight. The V's swing arm angle is higher than most, and the chain tightens as the suspension is compressed (due to this angle).
trialsguy is offline
post #5 of 18 (permalink) Old 06-10-2010, 01:41 PM
acinonyx's Avatar
Since the question is how do I care for my chain:
Every other gas fill-up, while the chain is "hot"
*WD-40 and a rag to clean the chain, applied at the bottom near the exhaust
* wipe the chain with a clean rag near the exhaust to clean off excess WD-40
*Light spraying of Dupont Multi-Lube with Teflon (blue can), applied at the back of the rear sprocket
Total time: usually under 15 minutes.
-Never mistake kindness for weakness.
-Harley Davidson rEvolution engine (V-Rod): Designed by Porsche, detuned by Harley.
acinonyx is offline
post #6 of 18 (permalink) Old 06-10-2010, 01:42 PM
Oil every 300miles and make sure the chain a bit wet. Use whatever is to your liking. Chian tension is about an Inches when you press at the centre point both way -up and down.
No big deal on the chain and you will have to replace it sometime. Only question is how offen and that will depand on your care for it.
A lot of therad here so take your time and cheeck it out.
post #7 of 18 (permalink) Old 06-15-2010, 03:12 PM
jman's Avatar
I use the Dupont Teflon lubricant as noted in a previous response.
My method:
I back the bike up onto a Harbor Freight wheel cleaning stand (http://www.harborfreight.com/motorcy...112&zmap=98800), then clean the chain, as recommended by the service manual, with kerosene using a small brush, then wiping it down with a shop rag. Once dry, I then spray on the lube. Works great!
jman is offline
post #8 of 18 (permalink) Old 06-15-2010, 03:52 PM
gotfz1's Avatar
wd40 and tension check every few hundred miles. I always bias a bit to the loose end of the slack spec, loose chains are happy chains. You can do more if you wish but I've seen plenty of chains last forever doing only this.
gotfz1 is offline
post #9 of 18 (permalink) Old 06-15-2010, 04:48 PM
Pretbek's Avatar
Sometimes I like to be a lazy a$$ [email protected], which is why I use Dupont Teflon Multilube.
I lube my chain hot (at the end of a ride) about every 400-500 miles. The chain always looks great so I don't clean it, just lube it.
Pretbek is offline
post #10 of 18 (permalink) Old 06-15-2010, 10:00 PM
sharrison56's Avatar
The Teflon lube does a pretty good job of cleaning the chain and doesn't appear to attract much crap.
Steve
Now I have four!
sharrison56 is offline
post #11 of 18 (permalink) Old 06-15-2010, 10:52 PM
I like to use wd-40 for cleaning and then wiping off all build-up.Then using white lithium grease in a spray can.Works great and is cheap.
inroads is offline
post #12 of 18 (permalink) Old 06-15-2010, 11:52 PM
VerstehenZee's Avatar
Steve, Where on earth do you ride??
+1 on Dupont Teflon stuff
V-Zee
VerstehenZee is offline
post #13 of 18 (permalink) Old 06-16-2010, 07:40 AM
It dries pretty quickly and doesn't seem to pick up grit the way white lithium or other chain lubes do. The chain still gets dirty, but the teflon spray washes a lot of that away when I spray it on. I do use a brass brush on it every couple of lubes to get ride of any build up of lube and dirt.
Steve
Now I have four!
post #14 of 18 (permalink) Old 06-16-2010, 08:39 AM
yellowdog's Avatar
http://www.amsoil.com/storefront/amh.aspx I spray it on about once a month, just wipe with a rag after spraying then a light spray again. 16,000 miles and I have adjusted the chain about 3 times.
yellowdog is offline
post #15 of 18 (permalink) Old 06-16-2010, 08:49 AM
dakotav899's Avatar
Dupont Teflon spray, every 300-400 miles...when I remember
08 Versys
97 Suzuki DR350
Pro Grip tank protector
Wee Strom hand guards
Nelson Riggs Soft Bags
Xelement Black mini tank bag
Xelement Silver ignitor Tri-Tex Fabric and Mesh Jacket with armor
Xelement Advanced silver and black Fabric Pants with level 3 armor
12V Powerlet
Nuvi 550 GPS
Yoshimura TRC slip on (stainless)
dakotav899 is offline
post #16 of 18 (permalink) Old 06-16-2010, 08:54 AM
The key,I believe,is too wipe off all you can no matter what you use.What you wipe off won't be used and just attracts dust.
Also depends where your riding.If your doing a lot of dirt roads just doush it w/ WD and wipe clean. Good to go,Just need to do it twice as often.
inroads is offline
post #17 of 18 (permalink) Old 06-16-2010, 11:42 AM
Hardware's Avatar
... I do use a brass brush on it every couple of lubes to get ride of any build up of lube and dirt.
You might want to use a nylon brush so as to not damage the rubber’ish O-Rings.
~~ Live Like You're Dying ~~
Hardware is offline
post #18 of 18 (permalink) Old 06-16-2010, 05:52 PM
i do every 400-500 miles
skizzo81 is offline
