looking for spare wheels - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 06-08-2010, 06:57 AM Thread Starter
john westcott's Avatar
Does any one know if the wheels from a 636 or other kawasaki will work on the versys? I know the EX650 Ninja will work, but how about others?
If you're not living life on the edge, you are taking up to much room.
john westcott is offline
post #2 of 3 (permalink) Old 06-08-2010, 09:31 AM
The 636 wheel is similar, but not identical. It uses a larger diameter axle/bearing, so you'd have to replace the bearings on a stock 636 wheel to something that works with the Versys axle.
Gustavo
Gustavo is offline
post #3 of 3 (permalink) Old 06-08-2010, 09:44 AM
Ninja 500R, Z750S,Z1000 all use 17" wheel , but not sure on bearing housing and disk rotor configuration.
http://www.motorcycle.com/.../kawasa...led-88776.html - United States
http://www.motorcycle.com/.../kawasa...iew-87863.html - United States
http://www.totalmotorcycle.com/.../K...0R-ZZ-R500.htm - United States -
correct me if wrong here.
