---dead battery--- - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 06-05-2010, 12:00 PM Thread Starter
---dead battery---
hii versys lovers...
I cannot ride my V for a long time and the battery seems to be dead. I bought a charger from that charges from home electricity.did it it was fine but after not riding it about 20 days battery seems to be dead again so do you guys think that I should change it..and how do I understand that the battery is dead and charging wont do any good...
thanks
kmkadm is offline
post #2 of 6 (permalink) Old 06-05-2010, 01:06 PM
4731
Guest
Posts: n/a
disconnect it, and dont let it go below 12v. Or use a permannet trickle charger. Too low and they dont recover/properly.
post #3 of 6 (permalink) Old 06-05-2010, 02:07 PM
Pegasus's Avatar
The new different type batteries now require different type chargers. One of the cheap 15-20 dollar chargers won't work properly on the V's battery. Take it to a shop to have it tested, they can tell you if it is ok, charge it if it will do any good, and explain about different chargers.
Pegasus is offline
post #4 of 6 (permalink) Old 06-06-2010, 05:14 AM
kmkadm,
Agree with Pegasus.
Try http://www.kawasakiversys.com/forums...ead.php?t=8598.
post #5 of 6 (permalink) Old 06-06-2010, 05:49 AM
At how many amps can your charger charge at, kmkadm? 1 amp won't do much. At least 1.2 amps is recommended for 20 hours on a battery with less than 11.5 V. Standard charge is 1.2 A for 5 to 10 hours, and quick charge of 5 A for 1 h on battery with over 11.5 V. You can also charge it at 2 amps for about 5 hours. See charging intructions on battery... Your battery's integrity may have suffered from being discharged over a long time.
post #6 of 6 (permalink) Old 06-06-2010, 07:07 AM
blipco's Avatar
Replacing a faulty battery early on is much cheaper than later after you've killed your charging system and have to repair that as well. Also, welcome aboard.
blipco is offline
