2015 Headlamp aiming - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 08-20-2015, 12:33 PM Thread Starter
Fly-Sig's Avatar
How does one adjust the headlamp aim on a 2015? I can see 3 bolt heads at the back of each headlamp area, two of which have some kind of splined washer thingamabob on them. Not wanting to break anything, I am hesitant to take a wrench to them.
Both headlamps are adjusted far too high. The low beam is more like a high beam, and the high beam is even higher.
Fly-Sig is offline
post #2 of 5 (permalink) Old 08-21-2015, 01:18 AM
andrewhtf's Avatar
check your manual. both the bolts with splined washer is the adjuster, i am not sure which is adjusting horizontal and the other , vertical.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #3 of 5 (permalink) Old 08-21-2015, 10:14 AM
Wulff81's Avatar
The manual gives you the low down. I had to adjust mine just the same as yours. It was super easy and fast.
Wulff81 is offline
post #4 of 5 (permalink) Old 08-21-2015, 10:35 AM Thread Starter
Fly-Sig's Avatar
Hmm, I didn't see it in the owner's manual but there it is. Thanks.
Fly-Sig is offline
post #5 of 5 (permalink) Old 08-24-2015, 11:08 PM
Jack your shock up and drop the front forks a little easy peasy
