Leaking coolant - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By fasteddiecopeman
post #1 of 19 (permalink) Old 08-18-2015, 08:00 PM Thread Starter
Leaking coolant
Seems I got a bit unlucky and have a slow (for now) coolant leak.
Something has hit the water pump on the underside (shown in pic) and taken a chunk out, making me sad just in time for spring. To help orient yourselves the right of the image faces outwards on the right hand side of the bike (from perspective of the rider) on the left side you can (just) see the oil filter.
Any advice on what you (or a shop) might do to remedy this?
It seems (to me) that there are three pieces - pump housing, an (apparently very thick) gasket and then the engine casing where you can see the stamped number 8 and the bolts with 12 on them. Am I seeing that right, or is that piece in the middle actually a separate metal part with gaskets either side?
So a couple questions for the more learned than I...
1. IS that a gasket or a seperate metal piece where most of the impact damage is?
2. If it is a gasket, can I replace it and do nothing else and hope it fixes things?
3. Has anyone opened up that part and give me an idea how thick the gasket is? (Asking because it should give me some idea if 2. might work)
4. Suppose I need to fill the part of the hole thats on the engine casing side - How might that be done while still making sure the surface of the gasket seal is smooth.
5. Can I skip 1-4 and just put some kind of goo that will cure so I can stop worrying? Are there any long term consequences of this? (Like accidentilly bonding surfaces together and making water pump replacement difficult / impossible)
6. what would you do about said problem?
Thanks in advance!
- David.
Dave_ is offline
post #2 of 19 (permalink) Old 08-18-2015, 09:06 PM Thread Starter
Ok, to answer one of my questions - that piece in the middle isn't a gasket - looks like the water pump housing (part # 13227)
Relevant parts pictures:
http://www.kawasaki.com/Parts/PartsD...2011/KLE650CBF
getting a sinking feeling that this is going to cost a few $$$ to fix...
Dave_ is offline
post #3 of 19 (permalink) Old 08-18-2015, 09:43 PM
No, the dirt did not knock a chunk off of your engine.
That is your water pump drain hole. You simply have a leak at the water pump seal (not at the water pump cover gasket) which can be replaced by a skillful mechanic.
post #4 of 19 (permalink) Old 08-18-2015, 11:09 PM Thread Starter
That is your water pump drain hole. You simply have a leak at the water pump seal (not at the water pump cover seal) which can be replaced by a skillful mechanic.
Looking like a bit of a noob right now aren't I? I've since learned that its a weep hole, which by some sorta coincidence exactly explains whats happening..... (slow fluid weep)
I will take it to a mechanic with more skill than I. It does look to my eyes like something hit it there, but that doesn't appear to be the larger issue.
Gut feeling is that its a fix it now type problem, and not a fix it when it gets worse. Even got a recommendation on which shop to take it to. Will ask them to pressure test the radiator cap too, and make sure the overflow system is correctly relieving pressure.
Will try to post a couple ride reports in appreciation this summer :-)
Dave_ is offline
post #5 of 19 (permalink) Old 08-19-2015, 10:29 AM
Rebuilding the waterpump is very easy, easily doable to the noob DIY shade tree mechanic. It's a good saturday project to have a few beers with.
Süsser Tod is offline
post #6 of 19 (permalink) Old 08-21-2015, 07:00 PM
You're gonna have to rebuild the water pump impeller housing. I had the same issue. Same picture posted on the same forum. It's a weak seal and ca used my coolant to almost drain all out. Fix it now, not later. Parts are not expensive. Labor is.
TonyVersysTheWorld is offline
post #7 of 19 (permalink) Old 08-23-2015, 05:48 PM
Thanks in advance!
- David.
Try SEARCH.
I had a leak on my '08 a few years back, and started a thread about how I fixed it.
post #8 of 19 (permalink) Old 08-26-2015, 03:50 AM Thread Starter
Apologies for not searching. To be fair I had originally thought something put a hole there and took me a while to understand that the hole is a design feature and its purpose (not my finest moment.)
You did start a thread! Appreciate the pictures in post #17.
http://www.kawasakiversys.com/forums...k-my-08-a.html
Thanks for the help. Hopefully I can resolve soon.
- David.
Dave_ is offline
post #9 of 19 (permalink) Old 09-07-2015, 08:25 PM Thread Starter
any tips on press fitting the new mechanical seal?
almost there and this seems to be the only tricky part left.
I was thinking of making something with a threaded rod to apply even pressure to the lip that ends up making contact with the water pump housing. (Making the housing hot and the bearing cold wasn't enough to allow press fitting by hand).
- David.
Dave_ is offline
post #10 of 19 (permalink) Old 09-07-2015, 09:34 PM
- David.
That's how it is done Long screw and washers.
post #11 of 19 (permalink) Old 09-08-2015, 01:30 AM Thread Starter
Ok, so I'm on the right track. Will I damage the seal if I remove the spring sealing piece placed inside the mechanical seal bucket?
Its hard to get a good press on the rim of the seal otherwise.
Appreciate your patience,
- David.
Dave_ is offline
post #12 of 19 (permalink) Old 09-08-2015, 05:03 PM
- David.
David - I'm PRETTY sure that I used an appropriate-sized socket to 'press' the new IN, after getting the old OUT.
post #13 of 19 (permalink) Old 09-10-2015, 07:50 AM Thread Starter
All back together now, press fitting with a bolt and a bunch of washers ended up doing the trick. Don't think its a great idea to take that thing apart.
Everything else was straight forward. My torque wrench seized, so wasn't able to get the torques to spec. Wish I could check the impeller bolt to make sure its ok. Maybe I'll take it apart in a week or two and check for tightness.
Very happy I decided to see if the torque wrench worked on the rear axle first.
No leaks so far after a half hour ride.
Dave_ is offline
post #14 of 19 (permalink) Old 09-10-2015, 12:46 PM
theres something to say about the old oldschool dial torque wrenchs..
post #15 of 19 (permalink) Old 09-11-2015, 02:17 PM
...Very happy I decided to see if the torque wrench worked on the rear axle first....
I believe that ANY torque wrench that will work on the rear axle is TOO heavy for stuff like the 'water-pump'. Harbor-Freight sells quite good inch-pound torque wrenches for as little as $10....
canit likes this.
post #16 of 19 (permalink) Old 09-13-2015, 07:00 AM
I don't trust my torque wrenches at very low torque values, they are pretty inaccurate at the "edges" of the scales and engine covers requiere what, 10 lb/ft? For that I have a small 1/4" ratchet.
BTW, whenever you're using a torque wrench you should not start and use it right away to torque something. Start at very little torque and torque a bolt that requires a lot of torque, that way you make sure that it is not seized and that everyting inside of it is working, then you work on whatever you're doing, butr even then you torque the bolts in a couple steps.
post #17 of 19 (permalink) Old 09-14-2015, 12:34 AM Thread Starter
$10 torque wrenches sound great. prices are a little steeper here locally (Australia). After my experience I think I'd prefer a dial/beam type anyhow.
The torque I wanted was at the lower end of the scale for the wrench, and I get that they're not as accurate there. ended up checking over the weekend to see if it was still tight, and it was. Medium-firm (less than a pickle jar) pressure on a torque wrench that was probably less than 4 inches long was enough to move the nut very slightly (less than a degree.) I doubt I've overtightened either, and if I have there's nothing I can do.
one day (hopefully soon) I won't be a rent-paying unpaid PhD candidate getting by on a few hours of tutoring a week, but for now I figure its not a bad outcome given I was working in the uni parking lot.
Either way I learned something.
Dave_ is offline
post #18 of 19 (permalink) Old 09-14-2015, 12:58 PM
Just checked the latest H-F advert in a magazine - the torque-wrenches are NOW $11.99 each.
BTW - "Car Craft" magazine did a test of torque wrenches several years ago, and rated the H-F ones as VG! (I have several, of EACH size.)
post #19 of 19 (permalink) Old 09-14-2015, 01:03 PM
...After my experience I think I'd prefer a dial/beam type anyhow....
I have BOTH (dial/beam type), as well as 'clickers'. Some jobs just work BETTER for me, w/ a clicker. For instance - torquing an oil-plug where the "dial or beam" would be UNDER the wrench, facing the floor. The IMPORTANT thing is to SLOWLY increase pressure till it 'clicks' - NOT just 'reef' on it!
