rear sproket change, 46 to 44 T - Kawasaki Versys Forum
post #1 of 17 (permalink) Old 05-31-2010, 01:27 AM Thread Starter
It all starts with having to put this on.
But thanks to the thread on wheel removal http://www.kawasakiversys.com/forums...ead.php?t=3109 it was easy.
Having no rear stand had to use my truck jack under muffler with a couple of tiedowns assisting the load as did not want to damage muffler.
the brake were hard to undo so had to have my vice grips for assistance
Axle came out real easy by just pulling through with my hand, no banging out required but nearly dropped the brake holder thingy on ground so i do not think it will like a hard knock on a concrete floor.
Put wheel on bench with blocks under tyres to protect rotor as per the manual.
Yes i do read my manual and am a very sad person as i have printed over 600 pages out if it.
New sprocket nuts torqued to 44 ftlbs as per manual and then due to a lack of freinds had to reinstall the wheel, used my knees and my bar under the tyre to help re line up and axle straight back in.
All back together but sad news is that it is now dark and to cold to ride may test ride tommorow
post #2 of 17 (permalink) Old 05-31-2010, 01:29 AM Thread Starter
For some reason could not post this picture in prevous post but this me using a bar under wheel with no freinds to help, boohoo
post #3 of 17 (permalink) Old 05-31-2010, 01:37 AM
I thinks you are all set to graduate as a Versys Grease Monkey. Good job Buddy and hope you test ride and post results.
post #4 of 17 (permalink) Old 06-01-2010, 12:13 AM Thread Starter
great test ride apart from a dodgy slip on the rear on a country road around a corner, i will blame the tyres and a bit of loose gravel, was at 110km/hr so heart rate went up. As far as the higher gearing, love it. 1st gear a lot more freindly IMHO around town. Have yet to really test it on a good trip with lots of twisties but not the right time of year here.
post #5 of 17 (permalink) Old 06-01-2010, 12:17 AM
and do take it easy with the new set up.
post #6 of 17 (permalink) Old 06-01-2010, 12:30 AM
Hi Mate, Thanks for your reply, sounds like you got the last 44 in stock,I can get a 16 front that should be all same maybe. Take care out there, catch ya
regards Jim
Kiwijim is offline
post #7 of 17 (permalink) Old 06-02-2010, 09:19 PM
antman325's Avatar
I'm a huge 44t fan! Can't wait to hear a full ride report once you get a chance to stretch her legs real good...talking about the bike btw!
"When It Rains, Get Wet"
antman325 is offline
post #8 of 17 (permalink) Old 06-03-2010, 01:50 AM Thread Starter
maygo for a ride to the brass monkey bike rally on sat if weather fine to test out bike.
http://www.brassmonkeyrally.org.nz/1.htm
post #9 of 17 (permalink) Old 07-04-2010, 02:30 PM
bigaussie's Avatar
Did you make it to the Brass Monkey ride?
The site didn't say if it was on or not, just "huge trail washouts and 1 ft snow".
Cheers
bigaussie is offline
post #10 of 17 (permalink) Old 07-04-2010, 03:18 PM
motojoe's Avatar
44t made my bike feel so much better at higher speeds. I can't believe kawi didn't make them like that from the factory
motojoe is offline
post #11 of 17 (permalink) Old 07-04-2010, 05:12 PM
'Cause not all of us want i that way....
post #12 of 17 (permalink) Old 07-04-2010, 07:42 PM
Does it change the readout on your speedo? Mine reads about 3 mph slower. Also, why must you remove your brake caliper? I remove wheels all the time and don't have to that.
BrittB is offline
post #13 of 17 (permalink) Old 07-04-2010, 09:09 PM Thread Starter
Cheers
Did not make it because I chickened out okay, getting soft in my middle age
post #14 of 17 (permalink) Old 07-04-2010, 09:23 PM
We don't call it chickening out, we call it "had something come up at the last minute"...
post #15 of 17 (permalink) Old 07-04-2010, 09:41 PM Thread Starter
I know, always getting myself in trouble for being to honest
post #16 of 17 (permalink) Old 07-12-2010, 08:14 PM
ADVCoot's Avatar
44T Changeover
I got around to changing my OEM rear sprocket to a 44T rear sprocket today. I had read through these posting several times to ensure I did it correctly.
Lessons learned:
You don't have to remove the rear brake caliper
It's easier to put the axle bolt in from the "chain side" of the wheel
Total time spent appx 1 hour
If doing this on a 90% humid day, go grab a cold one when finished...you deserve it!
Possible road test later this week.
There is never a shortage of new areas to see and explore.
How many lifetimes could one spend exploring every road that's worth exploring?
One of the great pleasures of my road trips is in the discovery of great places to drive or ride (sometimes by planning...sometimes by serendipity).
2008 Kawasaki KLE650 Versys
1989 HONDA NX250
ADVCoot is offline
post #17 of 17 (permalink) Old 07-13-2010, 10:28 AM
Nytrydr's Avatar
No need to remove the caliper. I didn't, the process took me all of about 15 minutes using my air tools. No special stand, just a jack stand under the right foot peg.
Tilt the bike on the kick stand and place the jack stand under the right foot peg to remove the wheel.
Before install of the wheel open up the brake pads so you will have any easy time lining up the rotor when installing the wheel. I use a large flat blade screwdriver to do this. VERY IMPORTANT: Be sure to pump your rear brake pedal to close the pads after the install before you ride. If you don't do this you won’t have any rear brake for that stop.
you probably already know all this, think Ill go adjust my chain.
Ride Safe!
Nytrydr is offline
