K&N 303 Oil Filter - Kawasaki Versys Forum
post #1 of 13 (permalink) Old 05-29-2010, 07:50 PM Thread Starter
K&N 303 Oil Filter
On the oil filter it states torque between 8-12 Nm which is different from the owner's manual which states 13 ft-lb and which I am assuming refers to the OEM oil filter. If that assumption is correct what do I torque the new filter to, 8-10-12, hand tight?
REDDOT55 is offline
post #2 of 13 (permalink) Old 05-29-2010, 08:16 PM
sharrison56's Avatar
hand tight should be tight enough, but I doubt that most torque wrenches are accurate enough for it to make a difference between 12 and 13.
Steve
Now I have four!
sharrison56 is offline
post #3 of 13 (permalink) Old 05-29-2010, 08:32 PM
Agreed!!
post #4 of 13 (permalink) Old 05-29-2010, 08:41 PM
bigaussie's Avatar
Fair comment, but one was "8-12 Nm" and the other "13 ft-lb"
8 Nm = 5.9 ft-lb
12 Nm = 8.85 ft-lb
13 ft-lb = 17.61 NM
"The happiest people don’t have the best of everything, they just make the best of everything."
bigaussie is offline
post #5 of 13 (permalink) Old 05-29-2010, 08:58 PM
Good point. I didn't catch the different units.
Steve
Now I have four!
post #6 of 13 (permalink) Old 05-30-2010, 01:27 AM
Hardware's Avatar
Go with the oil filter’s spec. It’s predicated on the desired compression for that specific filter’s gasket.
~~ Live Like You're Dying ~~
Hardware is offline
post #7 of 13 (permalink) Old 05-30-2010, 08:01 AM
furley's Avatar
I use k&n filters because of the nut, makes getting on and off so much easier, I have always torqued around 12 ft lbs and have never had a problem
________
FAKE WEED
furley is offline
post #8 of 13 (permalink) Old 06-04-2010, 08:50 PM
ayermedic's Avatar
I'm with furley no problem so far
ayermedic is offline
post #9 of 13 (permalink) Old 05-01-2015, 12:01 AM
chaofan's Avatar
I saw today that Auto Zone carries KN-303 oil filters for the V. Not everyone lives near a dealer, I know I am 18 miles away from the nearest motorcycle dealer so it I nice to be able to find some common parts and supplies a block away some auto parts stores.
chaofan is offline
post #10 of 13 (permalink) Old 05-01-2015, 12:05 AM
You can also get a Bosch 3300 there for about 5 bucks.
post #11 of 13 (permalink) Old 05-02-2015, 09:44 AM
same filter for 2015?
Will the K&N 303 and the Bosch 3300 also fit the 2015's? I imagine so, but in case someone has other info. My 2015 650 LT should arrive any day. I want to get stuff ready with a couple filters and a filter wrench.
I am going to do the MotoMan break-in, which mean changing oil at 20 miles. Pretty much as soon as I get it home from the dealer.
Squishman is offline
post #12 of 13 (permalink) Old 05-02-2015, 10:47 AM
hand tighten then 1/8th turn with wrench , run the bike and if nothing leaks your golden
post #13 of 13 (permalink) Old 05-02-2015, 12:11 PM
Same engine so i would say yes...My old Versys and FJR used the same filter. So i just took this off the Versys and put it on the FJR. Haven't bought a filter since 2010....
IMG_0120 by weljo2001, on Flickr
IMG_0115 by weljo2001, on Flickr
