Replacing Rear Brake Pads - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 05-29-2010, 06:45 PM Thread Starter
sharrison56's Avatar
Has anyone replaced the rear brake pads? I replaced mine today and now the pedal goes all the way down. There is a little clip that looks like a retaining clip for the pad that is against the caliper. I bed the brakes and that made no difference. When I took the rear caliper off I was able to get the pads to close. WHAT AM I DOING WRONG?
This is all the manual says.
Rear Brake Pad Installation
•Push the caliper piston in by hand as far as it will go.
•Install the anti-rattle spring in its correct position.
•Install the pad on the piston side first, then install the other pad on the holder.
•Install the rear caliper (see Caliper Installation).
Steve
Now I have four!
sharrison56 is offline
post #2 of 5 (permalink) Old 05-29-2010, 08:14 PM Thread Starter
Fix it! The retaining clip wasn't holding the pad correctly and it was stuck. I repositioned the clip and all is fine now. I might pickup a couple extra clips but they are mor ethan $6 a piece.
Steve
Now I have four!
post #3 of 5 (permalink) Old 05-30-2010, 05:50 AM
naz
naz's Avatar
could we have some photos plz? this small clip might has caused me some problems also.thanks
naz is offline
post #4 of 5 (permalink) Old 05-21-2011, 10:15 AM
jman's Avatar
Was this pretty strait forward job to perform? I have the service manual.
jman is offline
post #5 of 5 (permalink) Old 04-18-2015, 03:37 PM
Thank You
Just want to give a quick thank you to this forum for the great DIY tips and service manual we have here. Really made changing the front and rear pads on my bike a breeze. Took less than an hour following everything I read here. Great forum!
Madone1 is offline
