high temp grease on wheel spacers - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 05-23-2010, 06:40 PM Thread Starter
Hi All
About ready to replace my oem rear sprocket with a 44t, have read the thread on rear wheel removal, last time I removed a bike wheel was 20yrs ago on DR 500. My question is how much high temp grease do you use on the spacers? Any other wise tips on wheel removal/sprocket replacement?
just going use some of the high temp grease we use on our detroit coal spreaders on the boilers I operate so that should do the trick.
Phil
post #2 of 9 (permalink) Old 05-23-2010, 07:39 PM
just a little dab, only enough to cover the surface that contacts the axle. You don't want to over grease them, dirt will collect & cause more damage than good.
post #3 of 9 (permalink) Old 05-23-2010, 07:43 PM
Oh, and I don't think it has to be high temp. Axle grease works just fine, so does bearing grease, or just plain grease...
post #4 of 9 (permalink) Old 05-23-2010, 08:16 PM Thread Starter
cheers, got some grease I use for ride on mower will do then, just have to work out how to lift rear end of bike with out a proper stand, a friend made a sugestion to use a couple of ratchet tie downs to rafters in garage.
post #5 of 9 (permalink) Old 05-23-2010, 08:30 PM
I use Bel-Ray waterproof grease. I started using the waterproof grease on my Suzuki DRZ400S dual sport's swingarm, rear linkage, and steering head bearings, and on the wheel axles and spacers. So far nothing has rusted together between times I service the wheels or suspension. Of course I service everything in the the dual DRZ's suspension at least once a year, more than I expect to service Versys.
steven1955 is offline
post #6 of 9 (permalink) Old 05-23-2010, 08:45 PM Thread Starter
Can understand what you are doing on the DR i presume going through a lot more crap and water but my V mainly road riding and no river crossing I hope, seized up a TS 185 many years ago with lots of river crossings and no maint at all but was only 14 at the time.
post #7 of 9 (permalink) Old 05-23-2010, 10:37 PM Thread Starter
[QUOTE=jdrocks;84488]floor jack under the muffler. use a piece of wood on top of the floorjack pad, padding of some sort on top of the wood if you're worried about scratching the underside of the muffler.
Cheers for that, have done this method before to clean chain just was a bit concerned that the rear wheel removal putting to much pressure on the muffler
post #8 of 9 (permalink) Old 05-24-2010, 08:39 AM
[quote=kiwi 41;84493]
You need some ground clearance to remove the wheel, so do be careful on the floor jack. Best to work two if you intend to use floor jack.
Fastoman is online now
post #9 of 9 (permalink) Old 05-24-2010, 11:42 AM
I'll use the waterproof grease on even my on road Versys. I do ride in the rain on occasion.
