Squeaking Brakes - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 05-20-2010, 03:03 PM Thread Starter
Squeaking Brakes
Any one have squeaky brakes on their V? I have 3000 miles on her now and the front brakes have squeaked from day 1. 09 Green FYI, didnt know if it being the faster Versys made it squeak or something.
eparker202 is offline
post #2 of 16 (permalink) Old 05-20-2010, 04:08 PM
kenr74's Avatar
Mine is also green and squeeks some. Pads look fine.
1974 Kawasaki F11
2004 Yamaha WR450 plated
2014 Kawasaki Versys 650
kenr74 is offline
post #3 of 16 (permalink) Old 05-20-2010, 04:48 PM Thread Starter
just to clarify, when i am braking hard intitially there is no noise but when i am about to come to a complete stop, like a fraction of a second before and i am letting off the brakes a little i will get the squeak. or if i am just lightly braking at slow speeds it will also squeak. Mechanic told me it was dirty pads and that kawi is known for the squeak but it would go away once they were used a little well that was at 1000 miles and still squeaking 2000 later.
post #4 of 16 (permalink) Old 05-20-2010, 05:32 PM
I had the same problem. Read on the forum that cleaning and lubing my bobbins would help... it did.
http://www.kawasakiversys.com/forums...=brake+pulsing
"I refuse to tiptoe through life only to arrive safely at death."
Banack is offline
post #5 of 16 (permalink) Old 05-20-2010, 08:56 PM
csa714's Avatar
I checked out the 2009 Kawasaki production cycle. The greens V's are made on Saturdays. This is usually after all of the premier quality parts have been used on the BLUE bikes, and what is left over is used on the green bikes. The green V's brakes make noice because they are inferior!
Also noted on Kawasakis site is the fact that the Blue bikes are faster.
OK - nuf of the BS - mine occasionally squeak as well
Foo Fighter Rider
csa714 is offline
post #6 of 16 (permalink) Old 05-20-2010, 09:21 PM
Nytrydr's Avatar
But that doesn't explain why the Green V's are the fastest. Mine don't squeak...yet
Nytrydr is offline
post #7 of 16 (permalink) Old 05-20-2010, 11:08 PM
Use a brake cleaner to clean the brake bobbins.
Some KY jelly behind the pads can help.
I normally smoothen a bit the new pads before putting them in.
Metal sinter brakes squeak more than organic brake. But the bite is better.
Check your rotor if they are nice and smooth.
Sometime loose fitting brake pads in the brake pad also cause squeaks.
post #8 of 16 (permalink) Old 05-20-2010, 11:18 PM
Hardware's Avatar
ummm.... Oh never mind... Itís just too easy...
~~ Live Like You're Dying ~~
Hardware is offline
post #9 of 16 (permalink) Old 05-20-2010, 11:25 PM
MAybe jammed bobbins. Can we put the thread on Bobbin cleaning and maintainance as a sticky, It was posted sometime ago on how to service and clean the rotor bobbins.
Might be of help to all.
post #10 of 16 (permalink) Old 05-21-2010, 12:18 AM
+1 on making the bobbin cleaning a sticky that the project this wet/cold weekend
post #11 of 16 (permalink) Old 05-21-2010, 01:03 PM
StonedGP's Avatar
Was thinking the same thing....
StonedGP is offline
post #12 of 16 (permalink) Old 05-21-2010, 01:08 PM
Nytrydr's Avatar
Dang, got a squeak on the ride in to work this morning. is that Karma or what?
Nytrydr is offline
post #13 of 16 (permalink) Old 05-21-2010, 01:33 PM
LoneRanger's Avatar
Should I oil my squeaky brakes with WD-40 or Marine Grease?
I AM KIDDING!
My Red '08 Versys brakes non-squeakers.
LoneRanger is offline
post #14 of 16 (permalink) Old 05-22-2010, 04:53 PM
Nytrydr's Avatar
Hell spray down the whole bike with WD the stuff works! Ha! just kidding!
Nytrydr is offline
post #15 of 16 (permalink) Old 05-27-2010, 03:03 PM
I'll see if I have an extra bottle lying around the house somewhere
Mine are still squeaking. I'm going to WD-40 the bobbins tonight... I saw a thread where someone put a bolt with washers through each bobbin and twisted it while spraying. Sounds like it gives it a good cleaning. Wondering what size of bolt they use (this will avoid any trial and error work)
Banack is offline
post #16 of 16 (permalink) Old 05-27-2010, 05:04 PM
Did the bobbin thing the other day due to my front brakes being very jerky coming to a stop, it worked. I only had 8 mm bolts but as long as you put good flat washers either side it will work, just tightned up with the socket ratchet and i sprayed brakecleaner and i kept turning, stiff for a start then came loose. Gave the rotors a good clean while I was there. was not keen on wd40 around brakes
