2010 Undocumented Fuse - Kawasaki Versys Forum
post #1 of 29 (permalink) Old 05-17-2010, 10:00 AM Thread Starter
Hardware's Avatar
In addition to the normal fuse block; my 2010 has a single fuse/holder (wired in and with a spare fuse) under the seat & aft of the tool-kit (I donít have it in front of me but if I recall correctly itís a 5 amp).
Itís not referenced in the 2010 ownerís manual or the pre-2010 service manual. Does anyone know what itís for?
~~ Live Like You're Dying ~~
Hardware is offline
post #2 of 29 (permalink) Old 05-17-2010, 10:07 AM
Post a picture if you can and when you say undocumented, is it not in the wiring diagrame?
post #3 of 29 (permalink) Old 05-20-2010, 06:48 AM
Hardware:
any luck on the undocumented fuse? Just curious.
post #4 of 29 (permalink) Old 05-20-2010, 08:21 AM Thread Starter
Hardware's Avatar
Hardware:
Not yet... Iíve been too busy to get back to it...
FWIW, I will post a picture of it the next time I take the seat & luggage off but itís not going to reveal much. Itís just a single fuse/holder sitting under the seat, aft of the tool kit, on top of the `fenderí.
I donít see it in the 2007 wiring schematic and I donít have the 2010 service manual yet.
If I donít find out some other way, Iíll trace it out myself & see...
Hardware is offline
post #5 of 29 (permalink) Old 05-20-2010, 08:25 AM
juliozx7r's Avatar
"Undocumented" fuse
That is one of those fuses that shows up and takes other hardworking fuses jobs that have been there all along
Sorry, I couldn't resist. Actually I checked that fuse with a meter and if I remember right it is not live with the ignition on, off, engine running or not. I was looking for a handy switched source to run a Fuzeblock but it would not work.
Just looked and it has white with purple striped wires and goes into the main part of the loom. I just pulled it and it doesn't seem to do anything (maybe killed my 5 amp warp drive?) that I noticed with igintion on, off, or bike running. If I get a chance I grab the meter and see if I can figure it out. You got me wondering now too. I thought it was odd it uses a full sized blade fuse (hence the spare attached).
juliozx7r is offline
post #6 of 29 (permalink) Old 05-20-2010, 09:51 AM Thread Starter
Hardware's Avatar
LOL
Yeah, but now theyíre claiming that those are just jobs that the other fuses didnít want to do...
Hardware is offline
post #7 of 29 (permalink) Old 07-14-2010, 08:04 AM
Tigerpawed's Avatar
My Versys 2010 CA (calif version) has this weird fuse too. It sure looks like it should be doing something and not sitting there as a spare. I was hoping this thread was updated and someone figured it out. Oh mystery!
Tigerpawed is offline
post #8 of 29 (permalink) Old 07-14-2010, 10:10 AM
Jake's Avatar
i don't have a 2010 manual, but i would look at the wiring diragram and just look at the color of wire your dealing with, trace it back to whatever it goes to.
Jake is offline
post #9 of 29 (permalink) Old 07-14-2010, 10:16 AM
Jake's Avatar
Here are all the fuses it should have for an 09
ECU Fuse 15 A
Ignition Fuse 10 A
Fuse Box
Main Fuse 30 A
Jake is offline
post #10 of 29 (permalink) Old 07-14-2010, 11:39 AM
Tigerpawed's Avatar
Here's two photos showing the 5 amp fuse and holder. You can see the two color-coded wires, which are white with a olive-green stripe. One has widely spaced stripe, the other is more closely spaced.
Looking towards back of bike:
Looking from left side:
The wires route into the main wiring bundle. In the top photo, it curves around and heads towards the viewer. I didn't see anyplace obvious they appear at the far end, but I didn't take anything apart. I'm still at work (on break, or brake or somethin')
post #11 of 29 (permalink) Old 07-14-2010, 12:00 PM
csa714's Avatar
It is the dash vibe fuse -
Foo Fighter Rider
csa714 is offline
post #12 of 29 (permalink) Old 07-14-2010, 02:32 PM
Pegasus's Avatar
No doubt about it!
LOL
Pegasus is offline
post #13 of 29 (permalink) Old 07-14-2010, 03:11 PM
I also have it.
Main thing it probably does is getting in the way of a spare space that could be useful for storing small things.
But I will find out!
ninogui is offline
post #14 of 29 (permalink) Old 07-14-2010, 03:18 PM
Just pull the fuse ... and see what quits working ....
freewheeler is offline
post #15 of 29 (permalink) Old 07-14-2010, 04:26 PM
VerstehenZee's Avatar
Ha Ha Ha!! I love it. This method does work! But I'd rather use a schematic.
This is sort of in the same vein:
I once had to service my Jeep because it kept blowing ECM(brain) fuses. On the third trip, as the service adviser was giving me my keys, he told me they didn't know why it was doing it and couldn't fix it. I told him I could find the problem in minutes without a test meter or ANY tools. Surprised that a common schmutz like me could do this without "factory" service training or expensive equipment, he asked me "How?", (He was obviously looking for a "free" undocumented, money-making service tip, so I gave it to him)
I offered to wrap the ECM fuse in aluminum foil to demonstrate where the problem was originating (I told him to simply look for the smoke, but keep an extinguisher handy ).
He took it back in the shop immediately and the problem was miraculously repaired in minutes (unfortunately without my rather rudimentary, but very effective test procedure ) It was the ECM itself, just as I thought and am still on that same ECM today 10 years later. I love dealers (sarcasm) and NEVER, EVER, give any of them the benefit of the doubt (Kaw dealers included).
V-Zee
VerstehenZee is offline
post #16 of 29 (permalink) Old 07-14-2010, 10:31 PM Thread Starter
Hardware's Avatar
From another thread... http://www.kawasakiversys.com/forums...4434#post94434
Originally Posted by Capn Kirk View Post
I just looked in the 2010 factory service manual and in the appendix, it is listed as "Accessory Relay Fuse 5 A (Insert the connector from the bottom in the rear fender side bracket)"
That's it. No further mention on WTH it is..
Maybe for heated clothing or such?
Hardware is offline
post #17 of 29 (permalink) Old 09-13-2010, 01:50 PM
Tigerpawed's Avatar
The undocumented is now documented
Part of wiring diagram showing accessory outputs (white/blue stripe and black/yellow stripe) and accessory relay (orange/green stripe, black/yellow stripe, and white/blue stripe) and 5A fused circuit (white/blue stripe) that runs to the 5A accessory relay fuse located under the seat:
Drawing showing accessory terminal and accessory relay (#9):
Courtesy 2010 Service Manual.
post #18 of 29 (permalink) Old 09-15-2010, 08:54 AM
That's that mystery solved, both of the fuse and those spare wires on the LH side behind the radiator side cover. Could of used them for the 12V Aux socket on the dash, instead of fitting a new relay behind the headlight. At least I know where I'm going to get the supply from for the next farkle.... Cheers Tigerpawed
stotham is offline
post #19 of 29 (permalink) Old 09-15-2010, 09:29 AM
Pegasus's Avatar
I wonder why they overlooked that in the original manuals. It would have saved a lot of us time and money. Thanks for posting this info.
Pegasus is offline
post #20 of 29 (permalink) Old 11-26-2011, 03:17 PM
anybody know where to source a male end for that plug???
Dan
Wistrick is offline
