Adding electrical gadgets - Kawasaki Versys Forum
post #1 of 40 (permalink) Old 05-16-2010, 10:09 AM Thread Starter
Cruiseman's Avatar
Just wondering, how easy is it to add electrics to a Versys. Things like GPS power, driving lights, power port, etc?
Cruiseman is offline
post #2 of 40 (permalink) Old 05-16-2010, 10:30 AM
healdem's Avatar
as easy as any other bike...
theres plenty of capacity in the alternator sufficient to run heated clothing (I think the alternator is capable of generating around 330 watts, but I can't remember what the spare capacity is mind you, ie the amount available less whats required by the bike to run, show lights and recharge the battery and so on ). at the back of my mind I have a slight suspicion that the available power is about 200 watts... however I don't remember where that comes from and can't find any 'proof' that figure is correct - so DO NO rely on it.
most GPS's (and other electronic devices.. with the exception of transceivers) take minimal current so they shouldn't be a problem, its things like additional lighting and heated clothing that could draw to much current. I know you can run heated jackets and trousers and heated grips OR riding/fog lights, however running all depending on how much power they consume could be a problem. one thing to bear in mind is if you are running the electrical system at or near full capacity componenets will be running hotter and some Versys's have had problems with the rectifier connections leading to failure and for those in warranty a new wiring harness and a significant workshop delay.
fitting the electrical stuff could be an issue depending on how adept or scared you are at electrics. its relatively trivial stuff assuming you can find the parts (all you really need is some electrical cable, a standard 4 pin auto relay and so on). if you don't want to source your own parts you can get a handy 3 fused relay assembly from "Eastern Beaver" thats a breeze to fit.
If you are short of connections you could consider wiring the GPS into the headlight or even side/running light... but don't put any high draw devices on that connection.
healdem is offline
post #3 of 40 (permalink) Old 05-16-2010, 04:28 PM
Suggest you start by installing a FZ-1 relay off the low-beam. Then attach the other devicess to the relay.
ScottyNeal is offline
post #4 of 40 (permalink) Old 05-17-2010, 01:23 AM
bigaussie's Avatar
The FZ-1 will give you 6 circuits that you can choose to have switched or 'open' (always available but liable to run the battery flat)
The low beam is the best source for the ignition, because the light goes out for starting.
Depending on your GPS you may want that on an open circuit so you don't have to re-set it when you stop for gas, etc.
Good luck
bigaussie is offline
post #5 of 40 (permalink) Old 05-17-2010, 03:31 AM
Cruiseman.
Its easy. I just keep adding without any probelm. Just follow basis rules-RELAY and you are good to go and I dont use all the add on at the same time. Some of the add on below:-
Driving Lights
Super Horn.
GPS/Gear Indicator/Chain Oiler.
Cigar Lighter
Bag Brake lights
post #6 of 40 (permalink) Old 05-17-2010, 07:23 AM
Electric stuff
I have added:
2 extra brake lights
xm / Ipod radio plus antenna
Zumo gps
radar detector
driving lights
Plye stereo speakers plus amp
everything has relays and I am looking for a digital amp gauge, Not a volt meter. I want to make sure that I am not using more amps that my elect. system can replace.
Cb
cb1313 is offline
post #7 of 40 (permalink) Old 05-17-2010, 07:39 AM
Get one of these: http://www.fuzeblocks.com/
Mine is mounted in the space directly under the seat where it's protected from the weather, easy to access, and easy to wire. You can choose to attach your devices hot wired or switched, choose your own fuse rating, the ground bus is built in (decent grounds are hard to come by on the Versys) and the relay is built in. The whole device is compact and beautifully designed. Curt Gran, who developed the FZ-1, is a serious long-distance motorcycle rider who thought this product through with experience and consideration. He's also a great person. You won't go wrong with a Fuzeblock.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #8 of 40 (permalink) Old 05-17-2010, 08:03 AM
StonedGP's Avatar
+1 on the Fuzeblock. Very easy to install and add devices. Devices can be switched or unswitched with just a move of a fuse.
StonedGP is offline
post #9 of 40 (permalink) Old 05-17-2010, 08:27 AM Thread Starter
Cruiseman's Avatar
Could you post a photo of how you have your FZ-1 mounted?
post #10 of 40 (permalink) Old 05-17-2010, 09:13 AM
Originally Posted by cb1313 View Post
I have added:
Zumo gps
radar detector
driving lights
Cb
cb1313-Try this link for a nice volt meter. Design just for the versys
http://digilander.libero.it/JH61/index.htm
post #11 of 40 (permalink) Old 05-17-2010, 09:31 AM
MackDaddy's Avatar
I vote for a PC-8 from Jim @ Eastern Beaver myself...
30A total, 6 switched, 2 constant. Switched through a 30A relay to the battery as well.
MackDaddy is offline
post #12 of 40 (permalink) Old 05-17-2010, 09:34 AM
Aleeoop's Avatar
Not to make things more confusing for you but another option is either the Centech AP-1 or AP-2. The AP-1 has 8 switched circuits so they are less likely to run your battery down if you forget and leave something switched on. The AP-2 has 5 switched circuits and 3 "on all the time" circuits to connect things that have a memory that requires power and a very low power demand. Both devices are fuse blocks with electronic circuit boards and require a separate relay. The FZ-1 has a relay built in. I used the AP-1 and AP-2 on two different bikes so that if one component fails, that's all you have to replace. I have the AP-1 installed under the seat of the Versys. I don't have a picture yet but I do have a picture of the AP-2 installed on my Suzuki DR650SE. I will attach it.
Aleeoop is offline
post #13 of 40 (permalink) Old 05-17-2010, 12:07 PM
StonedGP's Avatar
Here goes.
StonedGP is offline
post #14 of 40 (permalink) Old 05-17-2010, 07:25 PM Thread Starter
Cruiseman's Avatar
The FZ-1 looks like an elegant solution as it allows you to choose between switched or constant connections, I supposed based on how the fuse is installed. I am a little confused as to where the +VT wire comes from. Needless to say, I am not an electronic genius.
post #15 of 40 (permalink) Old 05-17-2010, 09:12 PM
StonedGP's Avatar
I took it from the tail light. Make sure you don't use the brakelight wire like i initially did. DOH!
Here is a really good link to fuzeblock mounting/wiring project. http://www.kawasakiversys.com/forums...eferrerid=1947
StonedGP is offline
post #16 of 40 (permalink) Old 05-17-2010, 10:06 PM
Baron650's Avatar
Nice thread guys!
I got one for the TDM from Wing Man, I'm thinking like $25. But these are definitely an upgrade. Great mounting ideas as well!
Baron650 is offline
post #17 of 40 (permalink) Old 05-17-2010, 11:25 PM
tenover's Avatar
I added a fuse block and some heated grips with an inline fuse, using the tail light. I need to add a power outlet to charge my phone while driving on long trips. Can I simply attach the power outlet to the same fuse block with another inline fuse? Just worried about drawing too much power off the tail light......???? Thanks.
EDIT: I did NOT install a fuseblock, just a distribution block...Hence the inline fuse!
tenover is offline
post #18 of 40 (permalink) Old 05-18-2010, 01:17 AM
What's the difference between Fuseblock and distribution block, any images will be fine.
post #19 of 40 (permalink) Old 05-18-2010, 01:20 AM
tenover's Avatar
There are no fuses in the block. All gadgets can be wired directly to this distribution block, but need inline fuses. At least that's how I understand it. I did it using a link posted on this forum.....
tenover is offline
post #20 of 40 (permalink) Old 05-18-2010, 11:32 AM
Baron650's Avatar
The one I got from Wing Man is a Fuse Block. There are six fuse slots and screws to power your accessories. The power comes from the battery to the fuse block. Big Wire. Switching (only on when the key is on) comes from a switched source (like tail lights) with a T tap or similar via a relay.
Looks like the FZ1 and the AP-2 have some non-switched connections too, which means you can run the GPS to the block as well. You also gain the ability to charge bluetooth headsets overnight while camping!
Baron650 is offline
