Help!!! Switching from h7 to h4 headlight - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 06-01-2015, 10:21 PM Thread Starter
Mr. Fox's Avatar
Ok I feel like a total boob. Ok I am in the middle of a naked conversion and got my new headlight mounted up. I have seen several others (unfortunately no longer active), switch to an h4 headlight. How the hell do you wire it up...???? I have a single pole dual throw relay, found a diagram online on how to wire it up but nothing........what am I missing? Please if anyone has some advice, I am all ears.
Mr. Fox is offline
post #2 of 6 (permalink) Old 06-02-2015, 04:07 AM
and you don't need another relay
post #3 of 6 (permalink) Old 06-02-2015, 05:07 AM Thread Starter
Mr. Fox's Avatar
Ok. What confused me was that the oem light has low beam on all the time, then when high been turns on, the low beam stays on. Since I'm moving to a single bulb, shouldn't I have the low beam turn off when the high turns on? Thus the need for the new relay?
Mr. Fox is offline
post #4 of 6 (permalink) Old 06-02-2015, 06:02 AM
So you do need a 5 prong relay, to have only one beam on at a time, as illustrated here:
http://www.customfighters.com/forums...ad.php?t=63111
post #5 of 6 (permalink) Old 06-02-2015, 08:32 AM Thread Starter
Mr. Fox's Avatar
Yup, that's the diagram I used lol. I will double check my wires. Might have been in a hurry.
Mr. Fox is offline
post #6 of 6 (permalink) Old 06-02-2015, 05:42 PM Thread Starter
Mr. Fox's Avatar
Ok, I missed the ground wire from the bike. Whoops, that will do it. All is well, thanks!
Mr. Fox is offline
