2013 versys 650 coolant leak - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 05-26-2015, 10:31 PM Thread Starter
So my versys sprung a leak. Only has 2400 miles. Any one else seen a leak pop up in this area before?
ID:	64849   Click image for larger version
TonyVersysTheWorld is offline
post #2 of 8 (permalink) Old 05-27-2015, 12:34 AM
A few others have also had a coolant leak at the water pump seal... Scroll down for photos and more info:
http://www.kawasakiversys.com/forums...ad.php?t=17509
post #3 of 8 (permalink) Old 05-27-2015, 04:24 PM
It was a bit of work chasing that leak down, but it has NOT recurred...!
post #4 of 8 (permalink) Old 06-03-2015, 10:28 AM Thread Starter
Sooo, water pump needs to be rebuilt, under warranty thankfully. At least I get a free coolant/ oil change.
post #5 of 8 (permalink) Old 06-07-2015, 09:37 PM
hcb
I'll do you one better. I just tore mine down to put the ThermoBob in and found a similar, if not identical, leak to yours. Mine is a 2013, too. However, I just bought mine NEW from the dealership about 2 weeks ago (yes, 2 years old on the showroom floor) and has, wait for it, less than 200 miles (16 when I bought it and I put those on it last year on a test ride). Nice.
I came here tonight to find out what the problem might be but pretty sure it's the seal from the impeller and pump body to the engine drive shaft. And I guess that's what it is. NUTS! Was really looking forward to installing my ThermoBob so I could continue the break-in period....2 weeks and less than 200 miles...sad sad sad.
For those not familiar with water pumps in general; there is a shaft from a drive force (accessory belt, usually on cars/trucks/etc., or a direct shaft, obviously on the Versys and any non-belted engine) to the water/coolant pump which is just an impeller in a sealed container connected to the coolant system. Obviously the liquid needs to stay in the pump body yet the shaft must pass from the outside of the body to the inside. Coolant must not pass from the inside to the outside so there is a seal. There is commonly a void outside the pump body seal, between the seal and the drive force (a snout on the GM 350 water pump, for example, which sticks the belt pulley out to the belt plane, or, in the case of the Versys, apparently a void between the pump body and the engine block). Furthermore, there is commonly a weep hole placed so that coolant which leaks past the seal has a convenient place to discharge where it can be viewed, either to release the fluid or to simply allow easier troubleshooting, but probably both. In my third picture you can see the weep hole which appears to be the source of the fluid. I'll have to go back and highlight the image to make it clearer, though. Jeez...2 hours messing around with PhotoPaint and PhotoShop...last image is what I wanted. I normally do vector work, not raster. Arrrgghhh. I hope that image helps some folks.
With two failures in such short time (miles) I guess Kawasaki had a design flaw (or their supplier did).
FWIW. HTH. YMMV. EIEIO.
--HC
Name:	P1050875 (Medium).jpg
Name:	P1050876 (Medium).jpg
Name:	P1050877 (Medium).jpg
BMW, Honda, Kawasaki, Suzuki, Yamaha, Huffy...anything but a Harley.
hcb is offline
post #6 of 8 (permalink) Old 06-11-2015, 02:20 PM Thread Starter
Yes sir. Looks like the same issue. Warranty that bike. I really like my bike, however this is the second "common issue" I've had. First was a faulty oil pressure sensor which put my bike out of commission after my first 20 miles.
I also bought a left over 2013 in march but a guy I know has a 2014 that has the same issue with the pump seal.
post #7 of 8 (permalink) Old 06-11-2015, 02:44 PM
kawdog's Avatar
--HC
Attachment 65521
Attachment 65529
Attachment 65537
Attachment 65545
That is a problem on the BMW F650's too. It's starting to look like 2012 may be the optimum Vs. 650 year: although by not much.
kawdog is offline
post #8 of 8 (permalink) Old 06-16-2015, 10:54 PM
The water pump seal is a common issue. I've owned 2 KLRs and my Versys and they have all weeped coolant from time to time. If it does not drip on the garage floor, I probably would not worry about it. My KLR weeped coolant for a period of time and later the problem resolved itself. If the bike sits for a long period of time, it seems to weep more fluid. Guess this is a Kawasaki issue.
BTW - I also had a problem with the oil pressure sensor when the bike was new with less than 40 miles in the bike
Jim
09 Kawasaki Versys - Green
07 Kawasaki KLR 650 - Black
jharrissocal is offline
