rear axel socket sizes - Kawasaki Versys Forum
post #1 of 17 (permalink) Old 05-16-2015, 10:24 AM Thread Starter
I do not yet have my 2015 650 LT. But I wanted to make sure I had the correct tools. My socket set goes up to only 22 mm. What other ones larger than that will I need (for most normal tasks on the bike for that matter)?
Thanks!
Squishman is offline
post #2 of 17 (permalink) Old 05-16-2015, 11:41 AM
You'll need a 14mm allen socket for the front axle (the Harbor Freight socket set has one), and a 27mm socket for the rear axle.
post #3 of 17 (permalink) Old 05-16-2015, 11:54 AM Thread Starter
Ok cool. Just one 14mm allen socket? Does not the other side turn when loosen/tightening?
Same question for rear 27 mm.
post #4 of 17 (permalink) Old 05-16-2015, 01:15 PM
Time's Avatar
If you look at the front axle it's a giant bolt, threads into the left hand fork leg. So you just need the one 14mm allen and remember to loosen the pinch bolts on the right fork leg.
The other side of the rear is a 19mm head on the axle itself.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #5 of 17 (permalink) Old 05-16-2015, 01:18 PM Thread Starter
Cool. Thx Time. Can you or anyone tell me about the rear axel a little? What is needed, just one 27 mm socket?
post #6 of 17 (permalink) Old 05-16-2015, 01:54 PM
Time's Avatar
Pull the cotter pin and break the axle nut free before you get the bike on the lift, drop the rear caliper and bracket, tie it off don't leave it hanging by the line that's not good to do to brake lines. loosen the main nut and work the axle out, keep track of the spacers and where they go and how the fit. I put them back on the axle in the right order and orientation so I get them back on correctly. It's basically a simple job. Getting the wheel back on can be a fight at time but once you have it all lined up the axle will slide right in.
If you don't have a shop manual I'd get one. I have the Kawasaki manual for my 2012, it's saved me gref more than once.
2012 650 Versys
Time is offline
post #7 of 17 (permalink) Old 05-16-2015, 02:31 PM Thread Starter
Thx for the info. I do have a service manual. I doesn't say what size tools you need. I know how to take a wheel off, etc. Just didn't know what tools needed. I found a 14mm allen socket on amazon for under $10. Looks like I'll have what I need for whenever the bike decides to show up. Jeez, with the service manual, OEM light bar, OEM top case and bracket and a few tools, I have spent over $1000 already.
Pull the cotter pin and break the axle nut free before you get the bike on the left, drop the rear caliper and bracket, tie it off do leave it hanging by the line that's not good to do to brake lines. loosen the main nut and work the axle out, keep track of the spacers and where they go and how the fit. I put them back on the axle in the right order and orientation so I get them back on correctly. It's basically a simple job. Getting the wheel back on and be a fight at time but once you have it all lined up the axle will slide right in.
post #8 of 17 (permalink) Old 05-16-2015, 02:51 PM
Time's Avatar
Chump change! Buy a BMW...it stands for Bring My Wallet!
What was the Senator said? A million here a million there sooner or later it adds up to real money?
2012 650 Versys
Time is offline
post #9 of 17 (permalink) Old 05-16-2015, 03:21 PM
E327's Avatar
You're just getting warmed up. But it is a lot of fun and worth it.
E327 is offline
post #10 of 17 (permalink) Old 05-16-2015, 04:03 PM Thread Starter
I am hoping the bike suits me fine after I add that OEM stuff. I put probably more than $2500 into my Concours to make it just right. Then I sold it. ha. Obviously, I'll add some farkles here and there. But not that much!
post #11 of 17 (permalink) Old 05-16-2015, 05:30 PM
You can download the shop manual free of charge from this site. See stickied thread under tech section of this site. The 2010+ manual is on the second or third page of the thread.
post #12 of 17 (permalink) Old 05-16-2015, 06:11 PM
You can use a 1-1/16" (26.9875mm) socket for rear axle nut, and an adjustable wrench or 7/8" (22.225mm) wrench for rear axle head.
invader is online now
post #13 of 17 (permalink) Old 05-17-2015, 02:23 PM
Of the MANY times I've removed the rear wheel, I PROBABLY only needed to use a wrench on the right-side head once or twice.
post #14 of 17 (permalink) Old 08-29-2015, 12:08 PM
How about for a 2013?
I am going to adjust my chain and have looked at the manual for instructions, but it does not mention size for the rear axle nut sizes. Is it 27mm (I have) for the chain side and 22mm (I don't have yet) for the right side?
ESE_VERSYS2013 is offline
post #15 of 17 (permalink) Old 08-29-2015, 12:17 PM
Yes, but you'll ONLY need the 22mm IF the axle turns while loosening the 27mm nut.
post #16 of 17 (permalink) Old 08-29-2015, 01:33 PM
For the right side, you could use a 7/8" (22.225mm) instead of a 22mm wrench.
1-1/16" (26.9875mm) is always a good substitute for 27mm.
post #17 of 17 (permalink) Old 09-01-2015, 10:41 PM
Just adjusted my chain, 7th time in 7 years, err on the side of loose for the chain. It takes about 10 KM to destroy a tight chain. Torque is 80 ft lbs. Get yourself some new cotter pins. As others have said, no need for a socket on brake side, I have sockets, never use them, adjustable to turn axle so cotter pin hole is convenient. The nut I have a 1 1/16 6 point impact socket.
