Clutch Cable Replacement - How To? - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 05-14-2015, 04:51 PM Thread Starter
OK, Shade Tree Mechanics:
So I have ordered a new clutch cable - as a preventative maintenance option. I have 48,000 kms on my '09 Versys. I thought it may be wise to swap this cable before I head to Colorado in a few weeks. Between work schedules and Spring time poor weather, my options for getting the dealer to do the job are looking slim and I may have to pick up the part and do the job myself.
Any advice on how to? Pitfalls to watch for? The other option is to pack it along for the trip - just in case. Of course, if the stock cable goes, I'll still need to know how to install the new one. On the road side. Thanks much.
post #2 of 7 (permalink) Old 05-14-2015, 05:21 PM
Lube the cable before installing.
Run the new cable along the old cable to get routing right.
Loosen adjustment at engine end and back it off. Do the same at lever end. Once you get slack you can remove both ends. While you are at it clean and grease lever. Put some grease on barrel and exposed inner cable at lever end.
Connect up both ends. Do major adjust at engine end. Fine tune at lever end.
Now remove old cable.
waltermitty is offline
post #3 of 7 (permalink) Old 05-14-2015, 06:37 PM
I'd just stick the new cable under your seat and keep it as a back up. I'm 37k miles into my factory cable and its still fine.if your cable is in one peace and not frayed or binding no need to replace it
post #4 of 7 (permalink) Old 05-14-2015, 07:07 PM
Do you want to change a clutch cable in a warm, well lighted garage or in a ditch, at night on the side of the road while it is raining?
Clutch cables are cheap.
post #5 of 7 (permalink) Old 05-14-2015, 08:48 PM
BLACK DOG's Avatar
I'd prolly change out the cable where it's easy & stuff the old one under the seat. If you start out with doubts, they will dog you the whole trip (besides the cable is relatively cheap). This was an anual thing with my 79 wing....3 times on the road.
BLACK DOG is offline
post #6 of 7 (permalink) Old 05-14-2015, 09:32 PM
genehil's Avatar
I have my spare clutch cable pre-installed alongside the original - rather than under the seat or in a pannier. Each end is protected with protective tape. If I do lose my clutch cable it will take some of the stress out of the equation by just having to hook the spare up and continue along.
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #7 of 7 (permalink) Old 05-15-2015, 10:46 AM Thread Starter
I asked this question before I saw the replacement part. My incorrect assumption was that I'd be getting only a metal cable which would then have to be threaded through all the tubing. Having obtained the part I see that it is in fact a complete assembly, very easily switched.
Having made the change, I can see that my original cable still appears to be in good shape, so I'll hang onto it and travel with it for peace of mind, now that I know the install process.
Thanks for the help and advice all.
