12V Power - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 05-05-2010, 11:01 PM Thread Starter
Mawson's Avatar
12V Power
I want to wire a 12v power adapter straight to my battery for the sole purpose of charging my cell on an upcoming trip. It won't be kept on after the trip so I don't really need anything fancy and will probably purchase one at walmart or one of the local auto stores.
A couple of quick questions for the smart folks out here:
1. If there is nothing plugged in to it, will it drain my battery when the bike is off?
2. Do I need to wire in a fuse of any sort if I just want to power my phone or can I just go straight to the battery? If so, what size?
That's all. Just want to use it for one trip and then take it off. I know nothing about electrical stuff, so that's one of the major reasons i don't want to tap into wires and make it more permanent.
Advice is appreciated.
Mawson is offline
post #2 of 4 (permalink) Old 05-06-2010, 12:06 AM
DBL
I would wire in a fuse just to be safe. If something shorted across the outlet without a fuse, it would fry the wires leading all the way to your battery and possibly cause a fire. If you are just powering a cellphone, I would use a 5A fuse. The outlet with nothing plugged in should be an open circuit and should not use any power so there should be no worry about battery drain.
David
DBL is offline
post #3 of 4 (permalink) Old 05-06-2010, 12:11 AM
drumdaddy's Avatar
I agree with DBL there- especially the fuse- that is a must.
drumdaddy is offline
post #4 of 4 (permalink) Old 05-06-2010, 04:32 PM
Yes..Fuse it. Also, place the fuse as close to the battery as practical (on +) to protect the wiring from the fuse out to the 12V socket. I have seen people put the fuse near their device and this leaves the positive wire from the fuse back to the battery electrically unprotected from accidental wire damage & can still create smoke & flames under the tank & seat.
