Reserve light ? - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 05-01-2015, 09:14 AM Thread Starter
BEACHBUM's Avatar
Reserve light ?
My new (left over) 2012 is approaching 5k miles and recently found myself far from a station, low on fuel. I filled up at 212 on the trip meter and it took 4.6 gallons. So I had .4 gal. remaining and no reserve light flashing. I expected it to flash around .9 gal as the owners manual says. Just wondering if others have seen this?
BEACHBUM is offline
post #2 of 8 (permalink) Old 05-01-2015, 01:11 PM
kawdog's Avatar
Unless you are boringly consistent, it's hard to estimate gallons with gas sloshing around in your tank. I've only seen mine flash once when it was new to me. I ran out once 50 yards from a cheesy gas station I usually tried to avoid, where the pumps never had receipts working. It hasn't flashed low since.
When and if I see mine flash again, I'm heading directly to a gas station
kawdog is offline
post #3 of 8 (permalink) Old 05-01-2015, 04:43 PM
sonofnothing's Avatar
I put 4.6 gallons in yesterday without a FUEL light! But I see it sometimes and I put in about 4 gallons... kawdog's suspicions are correct, as I see the light on my boring ride to work, but didn't see it on a thrilling twisty 180 mile ride yesterday.. I go by the mileage.
sonofnothing is offline
post #4 of 8 (permalink) Old 05-01-2015, 10:31 PM
mikej's Avatar
I keep the dash on clock. When the tank is low, It changes from clock to fuel. I am not sure if it does it when on odometer or not.
mikej is offline
post #5 of 8 (permalink) Old 05-02-2015, 12:18 AM
chaofan's Avatar
If you are just looking for the blinking warning mine did come on twice and both times the miles were 212 - 214.
chaofan is offline
post #6 of 8 (permalink) Old 05-02-2015, 06:11 AM Thread Starter
BEACHBUM's Avatar
Yes, I want the warning, but like many of you I use the trip meter as a primary check. I normally fill up around 200 miles but this particular time I went past that and I was surprised the "blinky" didn't blink. I won't expect the warning in the future.
BEACHBUM is offline
post #7 of 8 (permalink) Old 05-02-2015, 06:52 AM
Time's Avatar
I never depend on the light. I know to fill between 170-190 and be happy. I learned when taking flying lesions that it's real hard to "Pull over to a cloud" so check everything twice before you start and always run your fuel burn charts.
I get about 46-50 mile per gal and it comes out at about 1 gal of reserve. I also it's not as hard to find a station on the right coast but I understand you guys on the left coast may have problems at time so keep a close eye on it.
PS I really did see a State Highway Dept sign warning that the next gas stop was 180 miles away. In WY as I remember.
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #8 of 8 (permalink) Old 05-02-2015, 05:57 PM
Mine works fine. I have about 40 - 50 kms left when it comes on. And yes it works regardless of the settings of the display.
