#@&# Fairing Tabs on Mk2 - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 03-20-2015, 12:52 PM Thread Starter
#*%$ Fairing Tabs on Mk2
In trying to gently remove my side plastic panels from the bike I somehow managed to rebreak the front loop tab on one side and freshly break it on the other. The panels are much easier to remove on the V2 vs V1 however, the tabs need to be built much stronger and more robust. Anyone else have this issue? Going to try to reform tabs with my Plastex Plastic Repair Kit.
post #2 of 9 (permalink) Old 03-20-2015, 04:59 PM
No, had mine off many times and no-where near broken tabs.
post #3 of 9 (permalink) Old 03-20-2015, 10:21 PM
No bproblems here eiather... taken them off like 50 times in 12 months.
Try lubing the rubber grommets with red rubber grease. this might make pull out easier especially if the weather is cold or the grommets are getting hard.
Gigitt is offline
post #4 of 9 (permalink) Old 03-21-2015, 02:06 AM
Avande's Avatar
I broke one of mine as well.
Lovin every minute of it!
Avande is offline
post #5 of 9 (permalink) Old 03-21-2015, 02:15 AM
A mechanic broke both of mine. Thought about trying to repair it, but I just left it. Don't think it made it any more rattly. Does it cause a problem for you?
davidg is offline
post #6 of 9 (permalink) Old 03-21-2015, 08:50 AM
kawdog's Avatar
I better check mine out to see how my mechanic is doing with the tabs
Until the CA member spoke up, the rest were way up North, where it is cold.
But the CA member could be in the mountains too, but statistically speaking...
kawdog is offline
post #7 of 9 (permalink) Old 03-21-2015, 09:22 PM
Mine were broken by improper installation. The loop in the fairing wasn't hooked over the tab in the frame. Press, crack.
davidg is offline
post #8 of 9 (permalink) Old 03-21-2015, 09:46 PM
BaileyMan's Avatar
I broke mine because I didn't know how to take the fairing off.
If my mechanic broke mine I'd make them buy me new ones...
2011 Imperial Red
A little bit of road rash
BaileyMan is offline
post #9 of 9 (permalink) Old 03-24-2015, 10:52 PM
E327's Avatar
I always lubricate all of the posts that are pushed into the rubber connectors with heavy wheel bearing grease. That helps tremendously when I'm taking the fairings off and on including the one at the front that has the tab ahead of it. Mine is a 2012.
E327 is offline
