Coolant return? - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 03-12-2015, 07:23 PM Thread Starter
Coolant return?
Hello Versys's owners. Been awhile since ive been over here, between work and life and the ADVersys giving us nothing but miles of smiles.
A few months ago I noticed a strange noise that can be best described as the sound coolant returning to the overflow tank? This happens after the bike has been ridden and immediately after shutting her down. I wouldnt think much of it other than its a "new" and rather loud sound and I am thinking something must be awry.
Anyone else experiencing this ?
Anyone consturctive thoughts on what to look at (coolant level in overflow tank is right a "low" when bike is cold)?
thanks,
-Brian
The Toad is offline
post #2 of 12 (permalink) Old 03-12-2015, 08:20 PM
Year and mileage? Was your coolant replaced yet? Your radiator pressure cap likely needs to be cleaned, and you may find evidence of dried coolant residue in the reservoir. Flush it all out along with the over-sprayed engine paint flakes also usually found.
invader is online now
post #3 of 12 (permalink) Old 03-12-2015, 08:32 PM Thread Starter
Thanks for the reply and info.
FWIW - 2008 with about 20K on it.
Again, I appreciate the info,
-Brian
The Toad is offline
post #4 of 12 (permalink) Old 03-12-2015, 09:01 PM
Drain and flush with distilled water. Refill with distilled water, and run engine for about half a minute. Drain and flush again with distilled water. Refill with long life Asian coolant, pre-mixed or coolant concentrate mixed with 50% distilled water. It takes about 1.3 quart total.
post #5 of 12 (permalink) Old 03-13-2015, 04:18 AM
it is called an expiation tank for a reason...... coolant does expand and contract with temperature....................
post #6 of 12 (permalink) Old 03-13-2015, 06:43 AM
a what tank?
post #7 of 12 (permalink) Old 03-13-2015, 10:08 AM
a what tank?
sorry expansion***
post #8 of 12 (permalink) Old 06-02-2015, 02:32 PM
gnarshread's Avatar
Has anyone had a definite solution to this? Last weekend I rode about 4.5 hours non stop at highway speeds, stopping only for fuel. When I got to my destination I heard a loud gurgling noise coming from the coolant tank. I didn't have enough time to get my helmet, ear plugs and gloves off to see what was going on but after inspecting the system everything looks to be in good order. Any ideas? Or should I just do a coolant flush and hope that sorts it out?
gnarshread is offline
post #9 of 12 (permalink) Old 06-02-2015, 03:18 PM
GiantAntCowboy's Avatar
I actually just fixed this on my 2008 Versys a week or so ago... At first it would only make the noise sometimes when shutting the bike off after a ride. Then it got worst and would happen fairly often, like every time I stopped and even at stoplights. It sounded like a gurgling (or pissing) noise and would sometimes cause coolant to drip out the overflow tube.
Anyway long story short, I fixed this by removing the Radiator Cap and scraping off mineral deposits which had formed on the rubber seal. I believe I put a little WD-40 or brake fluid to condition the seal after I cleaned it.
Alternatively you could just replace the Radiator cap with a new one since they're under $20. But the seal and cap on mine were both fine; the mineral deposits on the rubber were just preventing the cap from sealing and properly pressurizing the coolant.
It hasn't made the noise since; huge relief...
p.s. tips:
*- The Radiator cap is below the expansion tank, so if you remove the radiator cap before draining the coolant from the expansion tank it will overflow all over the place...
*- This should go without saying but: Let the bike cool down, or you will get seriously burned by pressurized coolant...
*- This is a good time to flush and replace your coolant.
2008 Versys 650
Been riding 8 or 9 years, and have owned 8 or 9 bikes; its an addiction I can't quit...
GiantAntCowboy is offline
post #10 of 12 (permalink) Old 06-02-2015, 04:07 PM
Yes, it's like I mentioned earlier, and like GiantAntCowboy found out. Never mind silviefox. 'He's' married to a 'man' ... You need to clean your cap. Flushing and replacing coolant would also be good as it's probably due. What year and mileage?
post #11 of 12 (permalink) Old 06-03-2015, 05:32 PM
gnarshread's Avatar
Thanks guys! I really appreciate it. I now know what I'm doing this weekend.
Invader: I have an 09 with 24108 miles.
post #12 of 12 (permalink) Old 06-03-2015, 07:46 PM
Oh and drain and flush your reserve tank as well... I also removed the water pump impeller to remove flaking paint, clean and grease the seals, then some grease on the water pump cover gasket (large odd-shaped o-ring).
