Warm engine before oil change? - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 03-10-2015, 07:25 AM Thread Starter
BEACHBUM's Avatar
Since my old bike had a thermostatically controlled oil cooler it made since to warm it up to open the thermostat. The versys, oth, is water-cooled. So is it just to flow the oil easier?
BEACHBUM is offline
post #2 of 7 (permalink) Old 03-10-2015, 07:32 AM
angst's Avatar
Oil flows better . . .
when warm. I run mine about 15 minutes, or a couple times around the neighborhood.
Cheers!
angst is offline
post #3 of 7 (permalink) Old 03-10-2015, 08:50 AM
IanThomas's Avatar
I always run any motor before an oil change. It lowers the viscosity of the oil and allows it to flow easier as well as helps get any foreign bodies into suspension and they have a better chance of coming out with the oil. I usually buy an extra quart of oil and flush the first quart just in case. it's a couple extra bucks, but worth the piece of mind IMO.
- Ian Thomas
2013 Versys
IanThomas is offline
post #4 of 7 (permalink) Old 03-10-2015, 09:11 AM
warm (not hot)((ok well hot too but dosnt have to be burn yourself hot)) oil flos much better insuring you get all of your old oil out befor putting fresh new oil in... i rode my bike to walfart (about 4-5 mile round trip) to pick up my oil then rode home and changed it.... warn oil will run out of the bike nice and quick...... after changing the oil in my old truck, in the snow i know the hell that is cold old oil............
silviefox is online now
post #5 of 7 (permalink) Old 03-10-2015, 10:21 AM
I always warm mine up..
post #6 of 7 (permalink) Old 03-11-2015, 12:28 PM
I ALWAYS change oil and filter after returning from a ride where the bike is fully warmed-up. I put rubber gloves on, and have a magnet against the drain-plug for the LAST few turns so it DOESN'T fall into the hot oil.
post #7 of 7 (permalink) Old 03-11-2015, 08:30 PM
I always dump the oil at the end of a long ride. I let it drain while I eat a meal, then finish the job.
twowheeladdict is online now
