Givi top case stop light connection repair - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 03-08-2015, 02:26 PM Thread Starter
E327's Avatar
I need to know how to disassemble the stop light connection in bottom of givi top case(e52). It came with used case and only works when wiggled a certain way. I hate(can't afford) to buy a new stop light kit when i think i could fix this if I could get inside it without tearing it up. Any advice is greatly appreciated.
E327 is offline
post #2 of 5 (permalink) Old 03-08-2015, 04:27 PM
If "wiggling" a wire makes it work - check for a LOOSE connection somewhere, but USUALLY near where you're wiggling.
post #3 of 5 (permalink) Old 03-11-2015, 10:26 PM
When I had a setup like that, I had to occasionally clean the contacts on the rack and case, and push the contact on the rack up a little to make sure it had good contact with the case.
davidg is offline
post #4 of 5 (permalink) Old 03-12-2015, 04:56 AM Thread Starter
E327's Avatar
Thanks! Between cleaning contacts and finally getting into bottom case contacts to tighten the connections, my stoplights are now working.
E327 is offline
post #5 of 5 (permalink) Old 03-12-2015, 08:17 AM
BaileyMan's Avatar
I had Givi brand lights in a case before, and the wires were super tiny and kept breaking. I ended up soldering a larger gauge wire to solve that problem...
2011 Imperial Red
A little bit of road rash
BaileyMan is offline
