Any feedback on Red-light magnets on bike? - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 03-07-2015, 10:43 PM Thread Starter
kawdog's Avatar
The expressway on-ramp redlights are not seeing me unless a car pulls up beside me (and regular red lights are 50/50 depending on if they are timed only), so I stop and go: nothing else I can do if a cage is not beside me.
CycleGear had them for $35 and says it will make your bike like a big magnet. For health reasons, I don't like that. Magnets may negatively effect your health (magnetics turns the galaxies.)
It also seems like it would help pinpoint you on radars better maybe - ?? They are strong magnets that they say to put on the bottom of your bike: by adhesive I guess since magnets, even strong ones won't attach to aluminum engines.
kawdog is offline
post #2 of 8 (permalink) Old 03-07-2015, 11:46 PM
I put a magnet on my 09..It seem to work just stuck it on the bottom of the of the oil pan no adhesive needed...
post #3 of 8 (permalink) Old 03-08-2015, 12:54 AM
Don't seem to have that problem here
post #4 of 8 (permalink) Old 03-08-2015, 08:19 AM
No problem here. If I encountered one on a trip, I take a right, do a u-turn, then another right. I don't encounter many triggered lights on my rides though.
You can pull a magnet out of a hard drive if you have one lying around.
post #5 of 8 (permalink) Old 03-08-2015, 09:52 AM
I can't say definitively if the magnets work to trip the sensors in the road - but I have 2 on my bike. One of these neodymium magnets on the front and one on the rear of my lower frame, like these - 1/2" X 1/4". I've used this vendor, but there are others.
http://www.ebay.com/itm/10-Neodymium...item53f7a66f0e
Just be aware that these 1/2" magnets are seriously strong. If you put them into a confined space on the frame, they may be impossible to remove. I wouldn't recommend sticking one on the engine - you don't want any metal held up anywhere in the engine, you want any metal to get to the drain plug for removal. A small one on the oil filter sounds OK.
I also have one of these small ones just stuck on in the depression on the head of my oil drain bolt -
http://www.ebay.com/itm/50-Neodymium...item29fa45bce7
Less expensive, and now you have enough for a lifetime of bikes - or a few for some friends.
visitor zero is offline
post #6 of 8 (permalink) Old 03-08-2015, 02:16 PM
post #7 of 8 (permalink) Old 03-08-2015, 02:21 PM
saddlebag's Avatar
Try extending your kickstand.
saddlebag is offline
post #8 of 8 (permalink) Old 03-08-2015, 04:49 PM
i personally just go thru them for the on ramps....... intersections.... well i do the same there too once i notice its clear.....
