3500 miles, leaking fork seal - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 03-26-2010, 03:24 PM Thread Starter
Basically a new bike, 2008 low miles, right fork seal is leaking. Don't understand.
kallkrish is offline
post #2 of 9 (permalink) Old 03-26-2010, 03:58 PM
Miles really doesn't have anything to do with it. It's on the annual maintenance checklist: front forks/rear shock absorbers oil leak inspect. I've had bikes that never ever leaked. I've had some seals that went early. It's a wear part, from what I understand.
lifesAnOcean is offline
post #3 of 9 (permalink) Old 03-26-2010, 04:03 PM
you can try and put some Vaseline on the forks close to the seal and compress the forks . Sometimes it might be a little piece of dirt that is making it leak and the Vaseline will push the dirt away.
turn8a is online now
post #4 of 9 (permalink) Old 03-26-2010, 04:08 PM Thread Starter
Well, I went ahead and bought the seals for both forks, also the dust caps. It will be all installed next week, bummer
post #5 of 9 (permalink) Old 03-26-2010, 04:29 PM
Before you do it, run a bit of camera film or similar under the seal and all around. Sometimes a bit of dirt gets there and holds the seal open, this cleans it out and stops the leak.
marc11 is offline
post #6 of 9 (permalink) Old 03-26-2010, 04:34 PM Thread Starter
Well, the thing is that it has already lost at least 2 ounces of fluid, and I would not like to leave one fork oil level too low. Nice idea.
post #7 of 9 (permalink) Old 03-26-2010, 04:36 PM
Of course you'll need to add some fluid, but if you get the dirt out it saves you the PITA of taking the forks all the way apart and it is a good trick to know if it happens again before that much fluid is lost.
marc11 is offline
post #8 of 9 (permalink) Old 03-27-2010, 06:17 AM
Which fork is it? As I understand it, only one fork (the right?) has any damping action. The other is only a spring. It may be the case (I don't know) that fluid is not essential in the other fork. I wonder how important the seal is on the side with no damping.
hsfarber is offline
post #9 of 9 (permalink) Old 03-27-2010, 06:18 AM
I should read more carefully. I see you said it is the right seal that is leaking. . . .
hsfarber is offline
