How do I get these plastic pins out? - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 02-17-2015, 04:50 PM Thread Starter
These are the pins around the cowling. I want to have a go at getting rid of the buzzzz.... 2010. Started prying with screwdriver but thought I'd check first.
[IMG][/IMG]
Gatorfan is offline
post #2 of 10 (permalink) Old 02-17-2015, 05:20 PM
Push the center pin in slightly and that will loosen/ release the outer ring. Then it all pulls out together. I had the same issue, seems backwards to me but it works.
post #3 of 10 (permalink) Old 02-17-2015, 06:01 PM
chadams66's Avatar
wait until you try and put them back in...plastic rivets was/is such a good idea...NOT!!
chadams66 is offline
post #4 of 10 (permalink) Old 02-17-2015, 06:38 PM
I replaced mine with these. http://www.amazon.com/gp/product/B001AWDX1K/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 .They don't tear up as easy as the stock ones..
post #5 of 10 (permalink) Old 02-17-2015, 06:52 PM Thread Starter
Perfect. Thank you gents.
Gatorfan is offline
post #6 of 10 (permalink) Old 02-17-2015, 07:00 PM
you can also find them at Lowes in the speciality hardware section
wampuspacker is offline
post #7 of 10 (permalink) Old 02-17-2015, 08:00 PM
Like Jeff says. Push the center until you hear a click and then pull the outer ring to remove. To re-install, pull the center pin out, place the thing into the hole and then push the center pin in. You'll hear a click when it's seated.
My wife's new Honda CTX700 is crawling with them but they work just fine if treated properly.
post #8 of 10 (permalink) Old 02-18-2015, 06:48 AM
If you can reach the other side you can push the pin out in the center with a flat blade screw driver. See you tube videos for easy HOW TO removal. My dealer charges $3 each for these, better to buy in bulk off of EBay or Amazon and keep a few spares around. The Versys uses only one size. Does anyone know what size that is?
post #9 of 10 (permalink) Old 02-18-2015, 06:58 AM
Marylander's Avatar
Cool, I will be heading to Lowes today. The bodywork on my cbr1000rr is mostly attached with cumbersome snap in tabs and push rivets (I guess someone thinks the bike looks prettier if you can't see screws holding the bodywork on). I've lost a couple through the years...
Marylander is offline
post #10 of 10 (permalink) Old 02-18-2015, 11:18 AM
From my post above.... http://www.amazon.com/gp/product/B001AWDX1K/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
