Throttle Body Syncronizer - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 01-02-2015, 12:27 PM Thread Starter
Anybody have any recommendations on a synchronizer set up that works well for a V? I have read here that some don't fit very well, but I cannot readily find the thread now.
Thanks,
John
MrTripwire is offline
post #2 of 11 (permalink) Old 01-02-2015, 12:51 PM
lacucaracha's Avatar
http://www.ebay.com/itm/like/1711990...lpid=82&chn=ps
This could work, but almost anything will do. The fit doesn't really matter since most of them come with enough tubing to reach into the engine. I have a fluid filled 4-bank from when I had to tune carbs on my XJ-650 Seca, but you can block off the meters you don't need.
I recommend fluid over needle gauges as they tend to be smoother. Not as cheap unless you build it yourself. There are plenty of tutorials online, but you will have the chance of sucking it into the engine if you mess up.
2014 Versys ABS
lacucaracha is offline
post #3 of 11 (permalink) Old 01-02-2015, 01:14 PM
This is the best one I have ever used: http://www.carbtune.co.uk/c.com/
waltermitty is offline
post #4 of 11 (permalink) Old 01-02-2015, 06:28 PM Thread Starter
Thanks guys. The Carbtune looks like a nice kit. Is there a U.S. distributor? I also looked at some of the DIY apparatuses people have come up with. Seems simple enough for what I need. This guy has one that can't suck water into tubes. http://youtu.be/Y_WDF6glD5k Maybe I'll give it a try.
Thinking into it brings up another question. The service manual states to use an external tachometer. Is there an easy access to a tach signal if you don't have one with an inductive pick up.
Thanks again,
John
post #5 of 11 (permalink) Old 01-02-2015, 06:32 PM Thread Starter
I should also ask, is it necessary to have an external tach?
post #6 of 11 (permalink) Old 01-03-2015, 02:33 PM
My "Carb Stix" look pretty much like that, and - NO - I don't use an external tach.
post #7 of 11 (permalink) Old 01-03-2015, 09:21 PM
Here is how I synced my throttle bodies just after I bought the Versys.
A Homemade DIY manometer - just a loop of PVC tube filled with 2-Stroke oil (as it coloured blue).
I needed a digital multimeter so bought one with a RPM inductive pickup to set the RPM correctly.
Gigitt is offline
post #8 of 11 (permalink) Old 01-04-2015, 08:08 AM
Smiley's Avatar
I bought the Morgan Carbtune many years ago and it is very high quality kit. Bought online and it was shipped to Canada in a matter of a few days. I have bought other kit from Britain and I am always impressed how quickly they get products to me. Faster than Canada Post to Vancouver from Ontario!
Smiley is offline
post #9 of 11 (permalink) Old 01-04-2015, 09:05 AM
I had a similar experience. Bought one from their site online and it was sitting on my doorstep three days later. Three days! It takes a week for me to get something from California.
post #10 of 11 (permalink) Old 01-06-2015, 12:07 PM
I have the same tubing-on-wood setup. If you do this, just fill it with oil or ATF fluid or something. Dont do water, as there is a chance that you will suck whatever is in the tube into the engine. Oil and ATF will make the bike smoke for a bit but wont do any damage. Water might.
2009 Versys 650
1975 Kawasaki F11 250
1972 Suzuki RV90
Mattydiah is offline
post #11 of 11 (permalink) Old 01-06-2015, 03:34 PM
Yes, that's what I did, too -- bought a CarbTune directly from Morgan's site, carbtune.com, for 46 pounds in 2010. I highly recommend it.
Syncing the throttle bodies is a pain, though. Big hands please the ladies, but they don't fit into Japanese motorcycles.
2009 Versys
2004 EX-500
Holden is offline
