problem - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 12-08-2014, 04:24 AM Thread Starter
problem
I have a 2008 KLE ABS with 44000 miles. The bike starts on the button and the automatic choke kicks in for about 3-4 minutes. As soon as the choke turns off the revs drop and the bike stalls. When I restart it it either runs ok or takes a couple of attempts and then runs ok. Very occasionally the revs will drop when filtering through traffic at low speed but when this happens the bike starts ok. Apart from this problem the bike runs just fine, no smoke, doesn't use any oil and pulls through all the gears like it always has done. Does anyone have any clue as to what might be the cause of this problem? Where and what do I start checking? Obviously I want to avoid hefty garage charges as hopefully it will be something that I can identify and fix myself.
Many thanks
jacko141 is offline
post #2 of 3 (permalink) Old 12-08-2014, 05:06 AM
was there really the need to post this 3 times on the same forum?
, turn your idle screw in 1/4-1/2 turn and see if it says running , if it dosnt repeat till it does, once it does turn the screw out till your idle is at 1,300(-,+50)rpm and see if it will start up and stay running then,
another thing to check would be your spark plugs they could be slightly fouled
Edit/Delete Message
post #3 of 3 (permalink) Old 01-01-2015, 04:52 AM
Carbon build up in the throttle bodies and on throttle plates can cause this.
It causes reduced air flow at idle position which can cause the engine to stall.
Check and clean them out with carburettor cleaner before making any other adjustments.
whitey66 is offline
