is a 2013 versys prewired for an outlet? - Kawasaki Versys Forum
post #1 of 15 (permalink) Old 10-28-2014, 10:26 PM Thread Starter
frozenhawaiian's Avatar
been looking around at various threads and I can't seem to find a straight answer in any of them so I'll go ahead and ask here. is my 2013 versys prewired for a 12 outlet? my plan is to flush mount a 12 outlet in the convenient flat plastic panel on either side of the gauge cluster, also planning on relocating the switch for my heated grips to the same panel. the dumbass who installed the heated grips before I bought the bike mounted the switch for the grips down on some of the body work, barely accessible when I'm riding. anyhow, any information is appreciated. I couldn't find an answer in the manual nor could I find an answer in some of the threads pertaining to 12v outlets.
frozenhawaiian is offline
post #2 of 15 (permalink) Old 10-28-2014, 10:42 PM
V-COASTER's Avatar
behind the left body panel there are two bullet connectors (2 live and 2 ground) switched accessory leads but they are only on a 5 amp fuse so good for a GPS, etc. You can see them if you look up behind the panel from underneath on the left side hanging down by the radiator.
2013 Versys1000
V-COASTER is offline
post #3 of 15 (permalink) Old 10-28-2014, 11:06 PM Thread Starter
thanks for the info, my guess is that one set is already being taken up by the heated grips, it would also probably explain why the switch for the grips is mounted where it is, low and on the left side. a 5a fuse should be fine, all it's going to be powering is either a GPS or a charger for my phone.
post #4 of 15 (permalink) Old 10-29-2014, 07:59 AM
it is pre wired --but you have to put a relay in the circuit to finalize the use your looking for. look up the kawasaki kit and it will show the relay number. the relay is one that is used on many models for other purposes. got one off ebay(ie salvage) for $5 instead of buying the whole kit
tmck49 is offline
post #5 of 15 (permalink) Old 10-29-2014, 10:50 AM
V-COASTER's Avatar
those two accessory leads are already on a relay. I checked and saw the relay in the wiring diagram.
2013 Versys1000
post #6 of 15 (permalink) Old 10-29-2014, 01:26 PM
is the 08 pre wired too?
post #7 of 15 (permalink) Old 10-29-2014, 02:44 PM
BaileyMan's Avatar
It's pretty easy to wire in a 12V outlet. There are threads here...somewhere...that have how-to's. I didn't wire in a relay to mine. I think I pretty much just spliced on some blade connectors to the outlet and connected it to a little receptacle thing under/below the left fairing that has switched power so that the outlet is only on when the key is on.
How's that for some good non-specific language and a run-on sentence...(I'm a speech and language pathologist, I ought to know better...)
2011 Imperial Red
A little bit of road rash
BaileyMan is offline
post #8 of 15 (permalink) Old 10-29-2014, 06:59 PM Thread Starter
thanks for all the info guys, as for a 12v outlet that's going to be flush mounted what would would you guys recommend? and am I understanding this right, there's 2 outlets? one is probably already taken up by the heated grips and the other should be free?
post #9 of 15 (permalink) Old 10-29-2014, 07:06 PM
V-COASTER's Avatar
I got a couple at a marine store Seadog brand I believe, not too expensive and a rubber plug for waterproofness.
2013 Versys1000
post #10 of 15 (permalink) Old 10-29-2014, 07:39 PM
mikej's Avatar
To the FrozenHawaiian, Search for user capn Kirk, and 12v outlet. He has a good post with parts and pictures for putting one on the left side connector.
mikej is offline
post #11 of 15 (permalink) Old 10-30-2014, 06:15 PM
Time's Avatar
Here's a link to the write up I did when I did my outlet.
Notice it's NO MOD! I didn't want to chop up a new bike so found the parts, listed them with part numbers, to make it a bolt up, plug in at less than half the cost of a straight up Kawasaki set up. Ans my bike STILL hasn't burned up!
http://www.kawasakiversys.com/forums...ad.php?t=20404
Or was that look THEN leap?
2012 650 Versys
Time is offline
post #12 of 15 (permalink) Old 11-12-2014, 10:24 PM Thread Starter
ok, so I found the relay on amazon.
http://www.amazon.com/Kawasaki-99994-0195-Relay-Kit/dp/B007A199DQ
and I'm using this outlet since I'm gonna flush mount it on the flat plastic area to the left of the console.
http://www.amazon.com/gp/product/B00791W8BW/ref=gno_cart_title_0?ie=UTF8&psc=1&smid=A3JHFA8958HW5J
that should be all I need as I understand it
post #13 of 15 (permalink) Old 11-13-2014, 10:06 PM
After you install the relay and power outlet you'll notice that there are 2 leftover connectors, those are for the OEM heated grip kit: 99994-0193
Süsser Tod is offline
post #14 of 15 (permalink) Old 11-13-2014, 11:20 PM
I wired in a flush mounted 12v dash socket for a ~$10 cost to provide a power source for my GPS and phone.
12v Dash Socket
12v Inline Blade Fuse
post #15 of 15 (permalink) Old 11-14-2014, 10:39 AM
kohburn's Avatar
12v Dash Socket
I used that same acc port from amazon on the left side http://www.amazon.com/gp/product/B00LZW5QAG/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
and use this on the right ride (the square base is detachable) http://www.amazon.com/gp/product/B00IRJH8CE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
kohburn is offline
