Clutch cable broken - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 10-02-2014, 06:47 PM Thread Starter
chid's Avatar
Clutch cable broken
This morning at 6, riding to work I pulled the clutch lever to change gears....
and then I felt it....prrrrrrrr....
I never had something like that before, but I knew immediately what it was..
I tried to use the lever as little as possible, changed the gears without it (except the first when stopped), I tried to synchronize as much possible so I don't have to stop at traffic lights....
I made to work, and when I looked at the daylight, the cable "frayed" next to the small barrel in the clutch lever... it was ok with no wire frayed about 2 weeks ago....
I have about 32 000km. never changed the cable, loob it every few weeks.
It was bended from the factory, so it always worked a little bit harder, but it didn't bother me too much...
I managed to get a new cable with the some help and I started to change it in the parking lot at work, no tools available.
It took me no more than 15 min, first time doing this. It was quite easy, a lot easier than I expected... Next time I'm lubricating the cable I will take it off from the bike instead of fighting with the lubing tool that doesn't work...
result: feels like I have a new bike... changing gears it's a dream now, never felt that easy, not even new...
For 25$ and 20 min.... you cannot go wrong with this.
Versys 2015 Green
chid is offline
post #2 of 9 (permalink) Old 10-02-2014, 06:50 PM
Did you grease the barrel on the end of the cable...I put a good amount of Bel-Ray Waterproof Grease on it....https://www.youtube.com/watch?v=i4ua...kbu-7nBO834fIy
post #3 of 9 (permalink) Old 10-02-2014, 07:23 PM Thread Starter
chid's Avatar
Yeap, took it out every time and cleaned it, lubricated...
Versys 2015 Green
chid is offline
post #4 of 9 (permalink) Old 10-02-2014, 08:21 PM
Woods riders will sometimes zip tie a spare cable to the one in use. That can be the difference between spending the night or getting home.
post #5 of 9 (permalink) Old 10-03-2014, 11:55 AM
MY experience w/ clutch cables in several Kawis (KLRs included) is that the engage/disengage point from the factory is TOO FAR from the bars, so that when you pull the lever back to the bars, it's trying to PULL the 'barrel' off once you're by that point. I set mine up so that the 'engage/disengage point' is MUCH closer to the bars, also making it a LOT easier to "slip" the clutch when necessary. Here's a pic of my '09.
post #6 of 9 (permalink) Old 10-03-2014, 12:13 PM
kohburn's Avatar
tempted to do that myself, or atleast stash under the seat. as my daily rider to and from work i really don't want to get stranded at work. (or in between)
kohburn is offline
post #7 of 9 (permalink) Old 10-03-2014, 12:25 PM
Cables last a really long time if properly taken care of. I'm leaving on a 20,000 mile trip in November and all I did was replace the cable before leaving. Lube the cable once a year or so and put grease on the barrel on the lever end and you won't have any problems. Even if you do you have plenty of warning. The cable breaks one strand at a time. Just inspect if occasionally.
If you cable breaks it is not the end of the world. Bike shift fine without clutch. If you have to stop you can just kill the engine a start it in first.
waltermitty is offline
post #8 of 9 (permalink) Old 10-06-2014, 09:46 AM
If I'm going someplace far off, I always pack a clutch cable. Cheap insurance against getting stranded.
Mattydiah is offline
post #9 of 9 (permalink) Old 10-06-2014, 12:12 PM
I carry a spare clutch-cable under the seat in BOTH my Vs.
