swingarm cracked - Kawasaki Versys Forum
Like Tree12Likes
post #1 of 57 (permalink) Old 10-02-2014, 01:50 PM Thread Starter
swingarm cracked
If you continue in this thread, you will read what the OP really did. Last Edited by Onewizard
See Post #20 first
My swing arm is cracked at 2places 1is at the weld of the axel and the rail and above at the other weld of swing arm . Has anyone herd of this ? Please any info can help me . Kawasaki is not honoring there warranty on this saying lack of chain maintenance caused this !!!! ( WHAT ) I've had motorcycles all my life and did all maintenance . ( I'm not saying I know everything there is to know but ?????????? chain Here's a good picture
Last edited by onewizard; 12-16-2016 at 10:00 AM. Reason: https://mail.google.com/mail/u/0/#inbox/148f85bdbae5115c?projector=1
peterbiltsteve is offline
post #2 of 57 (permalink) Old 10-02-2014, 02:23 PM
Can you post up some pics?
post #3 of 57 (permalink) Old 10-02-2014, 02:27 PM
Are you just talking to your dealer or someone above them?
post #4 of 57 (permalink) Old 10-02-2014, 07:51 PM
Lours_Polaire's Avatar
If you are an american, you could blow the wistle to that organisation that govern transport (DOT, NHTSA, ???) and regularly denounce unresponsible manufacturer for not recalling defect that's putting american life in jeopardy
Or maybe the treath of that could make kawi move ...
LOP
Lours_Polaire is offline
post #5 of 57 (permalink) Old 10-02-2014, 08:13 PM
How would Kawasaki know that there was not proper chain maintenance? Did they send an inspector? This is just the dealer? If you can't get them to honor the warranty, do not buy a swingarm from that dealer. Tell them if they can't get it covered under warranty you will take it elsewhere to get the work done.
Why are they saying improper chain maintenance cracked the swingarm? Is there evidence of the loose chain slapping the swingarm?
post #6 of 57 (permalink) Old 10-03-2014, 11:38 AM
kohburn's Avatar
first step would be getting a second opinion
second would probably be a call to the kawi headquarters above the dealership
third might be a letter from a lawyer
kohburn is offline
post #7 of 57 (permalink) Old 10-03-2014, 12:13 PM
Yeah. What everyone said. I find it very hard to believe that a loose chain could slap the swingarm enough to crack it. I run my chains very loose on my track bikes and it hasn't even caused a scratch. Conversely, running it too tight.... I think you'd notice a handling /binding problem. I suppose a super tight chain could maybe cause damage, but that's a long shot.
HondaGalToo is offline
post #8 of 57 (permalink) Old 10-06-2014, 09:44 AM
I'd think a loose chain would eat its way through the chain sliders and into the aluminum a bit, at the worst. I cant imagine a scenario where a loose chain would cause aluminum to crack though
Unless they're trying to say that the chain ate through the swingarm, weakening it and causing it to crack due to less material being there? In which case, lol
Mattydiah is offline
post #9 of 57 (permalink) Old 10-06-2014, 06:53 PM
We have yet to see this alleged cracked swingarm on the Peterbilt, er, Versys....
invader is online now
post #10 of 57 (permalink) Old 10-06-2014, 10:07 PM
This might be like a previous post " Epic------------------Problem", that just fades away, off in the sunset
post #11 of 57 (permalink) Old 10-08-2014, 09:15 AM
On mine, those are some pretty beefy welds. Hard to see how I could get them to crack, short of a collision. Bad chain maintenance? Ok... perhaps, by having your chain run over by a truck, while still attached to the bike...
visitor zero is offline
post #12 of 57 (permalink) Old 10-08-2014, 04:31 PM
post #13 of 57 (permalink) Old 10-08-2014, 07:38 PM
Maybe he is trying to buy a use swingarm, and afterward, bang some crak in it to show us ...
Sorry, could not resist with all the hoopla
post #14 of 57 (permalink) Old 10-13-2014, 07:38 AM
Rick's Avatar
Looking at the photo, wow. Write them a letter, explaining that you are going to forward that pic along to the NHTSA, and Momma Kaw will gladly swap you for a new swingarm. Their alternative would be a recall to check everyone's swingarms for cracks. Safety issues get a heck of a lot of attention these days, and law firms get moist in the crotch when things like this arise.
2012 Versys
2007 Honda VTX 1800C
Sold everything else
Rick is offline
post #15 of 57 (permalink) Old 10-13-2014, 08:37 AM
As I suspected, it is cracked but as a result of an accident, or some type of abuse... Just look at the missing chunk inside, and the bend in the swingarm. What we're missing is the rest of the story.
post #16 of 57 (permalink) Old 10-13-2014, 10:35 AM
it looks like someone shoved a metal rod into your sprocket or something to cause that grove in the swing arm a few inchs befor the crack
post #17 of 57 (permalink) Old 10-13-2014, 01:23 PM
I need to see a better picture of the crack but looking at the gouge in the inside of the swing arm and the mark on the sprocket that seems to line up with the gouge, I think someone has been prying on it for some reason or something got caught in it.
ray h is offline
post #18 of 57 (permalink) Old 10-13-2014, 02:16 PM
ddlewis's Avatar
Some sort of road debris landing at the perfect place/time to be caught and raked across the swingarm by the sprocket? the sprocket damage does appear to line up.
ddlewis is offline
post #19 of 57 (permalink) Old 10-13-2014, 03:30 PM
Kinda looks like the damage that would happen IF one of the sprocket bolts 'backed-off'....
post #20 of 57 (permalink) Old 10-13-2014, 03:37 PM
TowerMan's Avatar
Real Reason ? We Have a Winner Here!!!
+1
Maybe someone, when trying to undoing the front sprocket nut, used a small metal bar instead of a wooden block through wheel.
As only on one side and not through the rear wheel, the bar jammed at an angle and wrecked the swingarm due to excessive sideways point loading.
Swing arm now ruined / junk
at
TowerMan is offline
