The GOOD 16t front sprocket - Kawasaki Versys Forum
post #1 of 53 (permalink) Old 07-04-2008, 12:01 PM Thread Starter
Talking The GOOD 16t front sprocket
Ok fellas, I think we have a winner! Thanks to our friends over at Versys.co.uk (link here: http://www.versys.co.uk/index.php?op...1.45;topicseen), they have found the OEM kawasaki 16t replacement sprocket that will fit the Versys. It has the rubber damper just like our stocker. Its from the ZX6. Looks like it will be around $30 to $35.
16 tooth front sprocket with damper PN: 13144-0038
WOO HOO!!
P.S. I realize you have to login to see the thread above, sorry 'bout that, but I don't know any way around it, & I wanted to give credit to the proper folks...
post #2 of 53 (permalink) Old 07-04-2008, 01:16 PM
Hooligan's Avatar
What year? The ones I found on Bike Bandit are 15 tooth.
Graham
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
States I've ridden in so far
Hooligan is offline
post #3 of 53 (permalink) Old 07-04-2008, 01:23 PM
Hooligan's Avatar
Never mind! Found it!
Graham
Hooligan is offline
post #4 of 53 (permalink) Old 07-04-2008, 03:32 PM
Thanks for the info. Think that I'll try one out for size!
Scarey is offline
post #5 of 53 (permalink) Old 07-04-2008, 03:59 PM
xprovince's Avatar
ok here is a very simple question . What are we gaining with a 16t sprocket over the stock 15t ?
V
xprovince is offline
post #6 of 53 (permalink) Old 07-04-2008, 04:15 PM
You turn less RPM at highway speeds with a 16T. Should help get a little better gas mileage.
08 Versys is offline
post #7 of 53 (permalink) Old 07-04-2008, 04:21 PM
xprovince's Avatar
perfect thanks for the info !
V
post #8 of 53 (permalink) Old 07-04-2008, 06:47 PM
Hooligan's Avatar
...and it should improve the speedo error...
Graham
Hooligan is offline
post #9 of 53 (permalink) Old 07-04-2008, 09:04 PM Thread Starter
Front 16T sprocket with damper (Kawasaki # 13144-0038) is actually a Sunstar # 3A516. It's available in Canada from Motovan (390-7001) for $35.99. Sunstar # 32516 is the non-damper version. OEM rear is also a Sunstar...
Are you saying the Sunstar #3A516 has a rubber damper just like OEM?? Where were you when we were all whining about the non-dampered sprockets?
post #10 of 53 (permalink) Old 07-04-2008, 10:50 PM
Actually, Sunstar 3A516 (Motovan 390-7001) is a NON-dampened 16T.
invader is online now
post #11 of 53 (permalink) Old 07-05-2008, 02:24 AM
Bicyclebob's Avatar
Gear Ratio
Depends on what you are looking for. The jump up one tooth on the countershaft is pretty large. Might be better to go with the 38t rear.
  • 15/43 2.86:1
  • 16/43 2.69:1
  • 15/38 2.53:1
  • 16/38 2.37:1
Bicyclebob is offline
post #12 of 53 (permalink) Old 07-05-2008, 03:22 AM
  • 15/43 2.86:1
  • 16/43 2.69:1
  • 15/38 2.53:1
  • 16/38 2.37:1
Whoah!! Stock rear is a 46... 15/43 (+7%) is just 0.3% taller than 16/46 (+6.66 %). A 43 tooth rear is more common and easier to find. 15/45 would have the gearing about 2.3% taller, and about 4.6% taller with a 44.
post #13 of 53 (permalink) Old 07-05-2008, 08:26 AM
Hooligan's Avatar
WOO HOO! it's on the way to my humble abode as we speak!
Graham
Hooligan is offline
post #14 of 53 (permalink) Old 07-05-2008, 09:22 AM Thread Starter
Thanks for the link, Invader!! I just ordered one!
post #15 of 53 (permalink) Old 07-05-2008, 01:07 PM
antman325's Avatar
Once you guys are up and running with the new sprockets please let those of us trying to decide know how it worked performance wise.
"When It Rains, Get Wet"
antman325 is offline
post #16 of 53 (permalink) Old 07-05-2008, 04:53 PM
It works well, even without the rubber shoulder. I think some people said they could hear a bit more noise when running, but if you wear earplugs, it's not likely to be a concern.
The lower rpms (~7%) make a nice difference on higher speed runs, where it seems a lot more relaxed compared to what it was with the original gearing. I think the issues with the speedometer changes have been discussed before, but just in case someone reading this hasn't read the other threads - the speedometer reading does not change, what changes is the accuracy. You typically had a 8-9% error before, the speedometer will now be only 1-2% off the real speed. This means that you will still see 80 (or 82 to be precise) at 6K rpm, but before you were actually traveling at 75 MPH at 6K, now your real speed is 82, as indicated by the speedometer.
Gustavo
Gustavo is offline
post #17 of 53 (permalink) Old 07-05-2008, 05:23 PM
ZX6 16 tooth at Ron Ayers 31.99
I just ordered my 16 tooth, here is a link to the part
http://fiche.ronayers.com/Index.cfm/.../Transmission_
motordog1 is offline
post #18 of 53 (permalink) Old 07-06-2008, 05:46 PM
antman325's Avatar
Thanks dog. Just clicked on your link and got mine comin.
post #19 of 53 (permalink) Old 07-11-2008, 10:57 AM
Is more throttle needed to get the bike rolling after swapping to 16t sprocket? Does it cause the bike to lug at low rpm? Thanks in advance.
bear is offline
post #20 of 53 (permalink) Old 07-11-2008, 02:13 PM
My dealer told me the correct Motovan part number is 390-4516, and refused to order the 390-7001.
Anybody know if 390-4516 is the non-damped part?
I wish dealers just did what they are told.
choreboy is offline
Similar Threads
Bigger Front Sprocket Okanagan Rider14 Modifications - Performance - V-650 46 07-08-2011 09:30 PM
Tight front sprocket atgatt Technical Discussion - V-650 44 09-04-2008 08:27 PM
cleaning front sprocket? edthe Modifications - Performance - V-650 7 08-02-2008 08:09 PM
