No low or high beem - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 10-10-2009, 05:59 AM Thread Starter
Guest
No low or high beem
Is there somebody som can help me. There is no low or hi beem light on my bike. All other lights is ok. The fuse is ok but there is no 12v comming to the bulb. Then I try to find reley but dit not find any, can sombody help me.
With best regards
Valur Marteinsson
Valur is offline
post #2 of 7 (permalink) Old 10-10-2009, 06:58 AM
Are you testing the lights with the bike running?
I don't think the beam lights turn on withe motor off.
ChainLash is offline
post #3 of 7 (permalink) Old 10-10-2009, 07:59 AM Thread Starter
Guest
There is no driving light on the bike and that is not good when there is dark outside. It don't make a diff, if i'am driving or not.
Valur is offline
post #4 of 7 (permalink) Old 10-10-2009, 08:59 PM
I would recommend downloading the service manual to your desktop( is in the sticky above)--you can then trace the wiring circuit via the manual.
Good luck and let us know what you find.
Also Welcome aboard!!
2009 Lime green Versys
Hepco & Becker crash bars
Givi side carriers w/ E21's
Fenda Extenda
cut tail fender
black lower panels
Sw-Motech 20mm riser
Randy49 is offline
post #5 of 7 (permalink) Old 10-10-2009, 09:29 PM
The light may be out of adjustment, like pointing to far up or to far down and not at the road . A lot of folks here had that happen. But if they are completely dead when the bike is running (and I'm assuming you got off the bike to see ). Might be a loose connection the bulb itself...Wish you luck
contractor is offline
post #6 of 7 (permalink) Old 10-11-2009, 07:52 AM Thread Starter
Guest
Randy 49
Thanks now i can trace the wiring.
Valur is offline
post #7 of 7 (permalink) Old 10-11-2009, 10:06 PM
Your welcome Valur and Good luck!!
Fenda Extenda
cut tail fender
black lower panels
Randy49 is offline
